Old 09-03-2004, 06:40 PM   #1
Send a message via AIM to Bxclip
Default problem with centz III clutch
i install the centax III like it says in the book and when i put the screw in allt he way to the shaft it doesnt spin freely all the way whats going on?
Bxclip is offline   Reply With Quote
Old 09-03-2004, 07:10 PM   #2
afm
afm's Avatar
Default Re: problem with centz III clutch
Originally posted by Bxclip
i install it all liek it says in the book righ thtis and everythign butit doesnt sin freely if i titen the screw tothe shaft all the way whast going on?
Go here, very clear and good explanation:
http://www.mytsn.com/publ/publ.asp?pid=10534
AFM
afm is offline   Reply With Quote
Old 09-03-2004, 07:25 PM   #3
still dotn get it
Old 09-03-2004, 07:49 PM   #4
FAST1's Avatar
Place some shims on the bitshhh.
......or take some away.
FAST1 is offline   Reply With Quote
Old 09-03-2004, 07:52 PM   #5
i placed a whole bags worth do i titen screw as tite as i can cause if i losen it a lil it will spin freely is that ok? u got aim?
Old 09-03-2004, 09:30 PM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Post
Sounds like the shaft is recessed too far below the securing bolt. Try removing shims from behind clutch flywheel/collet if you have any there. Seems like its shimmed too high above the shaft, so you're binding up the center bearings. Is it just binding or draggng the clutch bell against the clutch shoe?
ezveedub is offline   Reply With Quote
Old 09-04-2004, 08:20 AM   #7
Old 09-04-2004, 08:38 AM   #8
Trader Rating: 16 (100%+)
That 0.5mm shim behind the collet is a standard shim size to start up, need NOT necessary the correct shim to place behind the collet, you might only need a 0.3mm or 0.4mm....
However, most of the engine should work with that 0.5mm shim, before you add or remove the shims, please make sure all the rest of the pieces are installed correctly and in the right position....make sure the clutch nut is tighten, also, make sure the clutch shoes spacer (the big round piece of spacer that has a counter sunk edge) is installed correctly, the edge should be facing toward the outside (GEAR) position......I had seen ppl installed that spacer the otherway, which made the clutch bell cannot spin freely...
If everythings are checked and the bell still cannot spin freely....you have too much shims behind the thrust bearing....remove 0.1mm at a time untill you have only 0.3-0.5mm space different like manuel said.
Old 09-04-2004, 08:43 AM   #9
but im missing the middle bearign the very small one u put in the cltuch bell can that be it?
Old 09-04-2004, 09:53 AM   #10
Default Small bearing
Hi Bxclip,
Yes that will be the cause of all your problems.
Is it the first time you built it?
What I mean is did the kit come incomplet?
If so you can call Serpent USA or Serpent Europe (depends on where you live) and they will sent you one for free, or pay you back the costs
If not, get a ceramic bearing as replacement, it works really well, and can stand the heat very well
840918001 is offline   Reply With Quote
Old 09-04-2004, 11:24 AM   #11
whats serpent usa number? iam bullshti and say i got 3 front tires and no belt tensioner
Old 09-04-2004, 12:43 PM   #12
i went to hobby shop it wsit was spinnin freel;y no when i spin it to the left wit will spin freely only to a poitn and then locks in but tot he right t will always spin freely
Old 09-04-2004, 03:54 PM   #13
anyone
Old 09-05-2004, 05:05 AM   #14
Default Centax problems
Hi,
What you can also do is the following.
Yopu can take out the crankshaft of your engine, and then install the Centax clutch. This way you are sure the crankshaft isn't moving inside your engine.
Take it out very carefully! Install all the parts on it like you are supposed to do on your engine.
When this is done you can check if all the parts spin freely, by giving the clutch a swing. During this swing the crankshaft should be helt firmly so it can not move!
If this works you can take off the whole clutch (there is no crankcase yet) and assemble it on your rebuilt engine.
Try this, it worked for me.
Old 09-05-2004, 08:35 AM   #15
i dunno for soem reason i played with it yesturday no noin what i was doin now it spins freely forever lol thank god no when u push the car its surpsose to go freely for liek 6 feet right?
Clutch Problem vazzo Nitro On-Road 8 06-20-2008 07:24 AM
rs4 3 ss clutch problem . never lift Nitro On-Road 3 01-20-2006 02:27 PM
R40 Clutch Problem Scott S Nitro On-Road 7 12-19-2004 09:16 AM
Clutch Problem B3boy Electric Off-Road 2 04-06-2003 12:20 PM
Is this a clutch problem? albertlam Nitro On-Road 31 03-17-2003 09:18 AM
