Old 08-25-2004, 02:34 PM   #1
kidDynomite's Avatar
Default <<( Battery Help )>> EP guys were no help
I started a thread in the Electric Forum and that was a mistake ... I don't think they read the posts:
http://www.rctech.net/forum/showthre...threadid=48505
Maybe they don't like nitro guys, whatever ...
Anyways, I wanted to try and use my flat 7.4V lithium battery pack from my Xray m18, and use it as a reciever pack in my nitro car. It's super light and lasts 4x longer than my AAA pack. It might even last longer at a lower voltage.
Is there a way to regulate it down to 6V?
I'm no electrical engineer, and I was really hoping to run into one in the other forum. So any help and/or answers would be greatly appriciated.
Thanks!
kidDynomite is offline   Reply With Quote
Old 08-25-2004, 02:43 PM   #2
Trader Rating: 16 (100%+)
You probably need a TRANSFORMER (that is the only THING that it can convert from 7.4v to 6.0v) or some kind of voltage resistence device to trim down to 6.0 V output.........that extra trasnformer will weight a TON.
For your information, those ppl from ELECT are far more intellegent then any college graduate in EE (in my opinion) They can play their 7.2V 3300 like a NASA engineer...............they can't give you a definite answer because you were asking something that is not a very good idea in NITRO or ELECT RC race car...probably not worth to even try.
Use (5)AAA, it will last you a whole day of racing including a 45 minutes or 30 minutes main....my R40 does.
Beside, lithium battery probably not the safest battery to play with....
And on my NTC3....I don't even bother to use AAA......car is way under legal weight already.
Old 08-25-2004, 02:52 PM   #3
Rookie, it was something I thought I'd like to try. I got the idea from a HK guy who uses one in his car. I wasn't able to ask him how he did it. And by the way, I'm sure some of the EP guys are very intelligent. That's why I took my question there first. But thanks for your thoughts. I guess it wasn't meant to happen.
Old 08-25-2004, 03:02 PM   #4
Data's Avatar
Default Re: <<( Battery Help )>> EP guys were no help
Data is offline   Reply With Quote
Old 08-25-2004, 03:08 PM   #5
Data's Avatar
this should work. the LM7806 has an max. output of 500mA, should be enough. you can drop C1 if you want, but make sure C2 is there.
becareful with those Li batteries, make sure the discharge rate is high enough, or the protective circuit is still there, otherwise it might overheat really fast.
also check this out, got some interesting circuits for RC.
data
Old 08-25-2004, 03:53 PM   #6
Default Re: Re: <<( Battery Help )>> EP guys were no help
Data, thank you! And thanks for "Tony's Website", it's already given me a ton of cool project ideas.
The captain should've replace #1 with you long time ago.
Old 08-25-2004, 06:18 PM   #7
drfritz's Avatar
Default Re: Re: Re: <<( Battery Help )>> EP guys were no help
well running 7.2 volts through your servos might make them hella fast, they wil burn out just as hella fast, if you can, remove two cell so that you only have five cells. sounds like to much work if you ask me, you can buy those flat cells and make a new rec pack if you are looking a flat light pack.
drfritz is offline   Reply With Quote
Old 08-25-2004, 08:05 PM   #8
Data's Avatar
Default Re: Re: Re: Re: <<( Battery Help )>> EP guys were no help
if you were talking about Li batteries, those 7.2V Li pack has only two cells, each cell is 3.6V.
Old 08-25-2004, 10:41 PM   #9
drfritz's Avatar
Default Re: Re: Re: Re: Re: <<( Battery Help )>> EP guys were no help
I did not know that.
I think ofna is who makes those brick cells though.
Old 08-25-2004, 10:46 PM   #10
compaq888's Avatar
Send a message via AIM to compaq888
Data, really good info, i just put it in my favorite's folder. I was going to say that maybe you can use a resistor that can be bought at radio shack, and it weighs practally to nothing, but DATA helped you out more than I can.
hahahahaha, at the transformer idea. Those things weigh the same weight as an RC car.
compaq888 is offline   Reply With Quote
Old 08-26-2004, 12:08 AM   #11
Data's Avatar
you can use two resistors to build a voltage divider, but then you need to optimize the resistor's value accordingly. using a voltage regulator is easier and more stable. also you need resistors with power rating >= 1/2W. typical resistors you get at radio shack are 1/4W and 1/8W.
not necessary.
Old 08-26-2004, 02:38 AM   #12
compaq888's Avatar
all i know is that you can use resistors to get different voltage, otherwise I don't know anything about electronics. I took more than a year of electronics but I just don't understand it. Thank god when we had a project to do I got the part of making a frame out of metal, i aced that part, i love working with metal, not electronics, even though my dad built tv's from the ground up without a manual at the age of 15.
I thought most transformers were heavy because our air conditioner transformer blew and I went to like 4-5 stores to get another one, and 95% of them looked to be the same size and weight, it's where the wires came out was different and their working capabilities.
Old 08-26-2004, 06:56 AM   #13
Put 2 1N4002 diodes in line with the positive pole. Every diode has about 0.7V drop out.
Mike
mindrev is offline   Reply With Quote
Old 08-26-2004, 08:10 AM   #14
tomkelley's Avatar
Don't forget, someone already stated that Lithium batteries are not the safest to be playing with.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 08-26-2004, 10:16 AM   #15
DickemDown's Avatar
http://www.htbatteries.com/Public_html/Rx%20packs.htm
i use li-poly cells in my m8 and my receiver packs for my 1/8 scale buggy. they are considerably lighter and the run time is longer.
anyway, go to the bottom of the link and you'll see a regulator switch. it'll regulate your voltage so i won't fry your gear.
good luck.
DickemDown is offline   Reply With Quote
Hey guys new here DemoT4 Electric Off-Road 3 10-11-2010 12:00 AM
Hey guys losi 8 racer Nitro Off-Road 16 07-24-2008 01:44 PM
Hey Guys DannyDrift Rookie Zone 2 12-01-2007 03:08 AM
Guys help me out!?? msm Electric Off-Road 3 07-17-2007 01:48 AM
2 ?'s for u guys siding88 Monster Trucks 4 05-17-2007 08:05 PM
