Old 08-25-2004, 11:01 AM   #1
GReddy's Avatar
Send a message via AIM to GReddy
Default noob question
how do i clean a air filter? just put it in a bag with air cleaner oil?
GReddy is offline   Reply With Quote
Old 08-25-2004, 11:20 AM   #2
j240z's Avatar
I would flush it with CLEAN fuel first squeezing the filter to release any dirt. Spray the fuel into the filter "inside out" so that dirt will go out of the filter instead of in (toward the carb side of the filter). Let it air dry and then put it in a bag or spray it with air filter oil.
j240z is offline   Reply With Quote
Old 08-25-2004, 11:26 AM   #3
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: noob question
really, do you clean it at all, for I don't. I just replace with a new one when it gets really dirty or torn up.
eddiethefish is offline   Reply With Quote
Old 08-25-2004, 11:39 AM   #4
kidDynomite's Avatar
Eddie, I do what j240z does after every race meeting. I then replace it every 4-6 meets. I have a fairly new Rody and it was idling super high after my first final main. Pitman temp it at 340 after the race. I stripped it down and found that something dinged the piston which then gouged the sleeve. So whenever it gets warmed up and the sleeve expands, a lot more air mixes in and then thermal break down takes effect. Cost me another $180 to fix. Whatever got in the engine could've happened when my pitguys changed the plug during a pitstop. But it could've happened through the filter as well. Don't take chances ... it could cost you more than a race.
kidDynomite is offline   Reply With Quote
Old 08-25-2004, 11:46 AM   #5
learning new things everyday. Thanks for sharing.
Old 08-25-2004, 11:59 AM   #6
Ditto that, Bro. You guys have all saved me a buck or two.
Noob Question Here. RobsbB Painting, Designs, Graphics and Photography 1 03-05-2008 10:56 AM
noob esc question Hasee Electric On-Road 4 09-08-2006 02:53 PM
got a noob question... ratcoon Rookie Zone 8 12-19-2005 05:46 PM
Noob Question Zala Electric On-Road 3 01-05-2005 09:34 AM
noob question siulung100 Electric On-Road 3 12-18-2004 03:24 PM
