Old 08-23-2004, 08:48 PM   #1
nick51's Avatar
Send a message via AIM to nick51
Default wiring starter box for 2 batts?
i am going to wire my starter box that was prewired for 1 gel cell but i bought it with 2 2000's packs, when connecting the batteries do i want to connect the + and + together or go from + to -??
I have a pic to show
nick51 is offline   Reply With Quote
Old 08-23-2004, 09:26 PM   #2
Rapid Roy's Avatar
You want to go + to -. That way you get the voltage up to 14.4
Rapid Roy is offline   Reply With Quote
Old 08-23-2004, 09:37 PM   #3
nick51's Avatar
i dunno if this matters but in my parents motorhome it has 2 batteries and they are wired + to + and - to -.
Old 08-23-2004, 09:42 PM   #4
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
If you do it that way you get twice to mah but not twice the voltage. He needs at least 12 volts to power the starter motor.
Racing4Evo is offline   Reply With Quote
Old 08-23-2004, 09:44 PM   #5
nick51's Avatar
oh ok, thanks for you help
Old 08-23-2004, 09:51 PM   #6
nick51's Avatar
1 more q, can i direct solder the connections to the battery and charge it or do i wanna disconect them
Old 08-23-2004, 10:06 PM   #7
Rapid Roy's Avatar
Direct soldering is fine if you don't mind charging the batteries with alegator clips. I would recomend deans connectors or another high quality connector though for ease of charging.
Old 08-23-2004, 10:08 PM   #8
Rapid Roy's Avatar
Also, you should cover the battery bars up on those packs so the batteries won't short out if they shift.
Old 08-23-2004, 10:43 PM   #9
nick51's Avatar
yea im ganna zip tye them down and put some foam inbetween them and on the sides. Yea i have aligator clips on my yokomo bcs double charger
Old 08-24-2004, 09:14 PM   #10
nick51's Avatar
it didnt work , sparks were flying out and the batteries got really hot. I had one side all wired up and then as i was connecting the other side it started to spark. Any idea whats goin on? Can someone dram a diagram on the pic to show me how to wire it. would it be safer to wire each battery seperate?
Old 08-25-2004, 02:55 AM   #11
teammpp's Avatar
ok. The white cable coming from the motor. Split it so you have your 2 separate cables (like + and -). Now solder 2 connections to one and 2 connections to the other so you have 2 sets of triple joints.
Now solder the connectors to the pos and neg of each battery separately and hook the 2 pos to one set of connections and the 2 negs to the other set of connections.
teammpp is offline   Reply With Quote
Old 08-25-2004, 07:44 AM   #12
Data's Avatar
try this
Data is offline   Reply With Quote
Old 08-25-2004, 11:40 AM   #13
nick51's Avatar
i have dual motors, but i will see what i can do. Thanks
Old 08-25-2004, 11:49 AM   #14
nick51's Avatar
Ok i got the spliting wires but didnt understand the rest.
is this sort of wut you mean, now should i just split the 2 wires and connect them to 1 battery and the same with the other?
Old 08-25-2004, 02:21 PM   #15
Trader Rating: 16 (100%+)
Try this....I think that will work, it works on my NTC3 box and my Serpent box with (3) 7.2V stick packs along with the DC plugs built-in....
???????need help wiring a starter box????????????????????? superdave2 Nitro Off-Road 19 08-15-2009 09:09 PM
Starter Box wiring TC3ElectricGuy Nitro Off-Road 2 08-13-2008 02:51 AM
Losi Starter Box Wiring MetalShield Nitro Off-Road 2 05-24-2008 08:19 PM
Starter box batts??? Chris08527 Electric Off-Road 5 12-31-2004 06:50 AM
BRAND NEW GS Racing TurboBox Starter Box with BRAND NEW Deans Wiring and Connectors racer rich R/C Items: For Sale/Trade 7 12-04-2002 11:19 AM
