Old 01-29-2011, 03:37 AM   #1
Send a message via MSN to jwright1
Exclamation Novarossi mr12 (standard) clutch help
Hi can anyone advise me how many turns in on the clutch nut I should go. I guess this nut changes how early/late the clutch bites. Cheers -James
It is a standard MR 12 for a mugen mtx 4 it has black shoes x4
W.R.C.R.T
jwright1 is offline   Reply With Quote
Old 01-29-2011, 05:47 AM   #2
quietstorm76's Avatar
Go in till you have about 1.5 threads showing. That should get you close enough to tune from. Tighten if it's too early, loosen if it's too late (slipping).
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-29-2011, 06:02 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
Keep in mind that the pretension on the spring is depending the clutch gap and with this question I wonder if you are aware that a to small or a to big gap can give a bad clutch.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Tags
clutch, clutch nut, novarossi mr12, turns
