Old 08-13-2004, 11:12 AM   #1
Regional Moderator
nitrous36's Avatar
Default RS4 3 Chassis Help
Last year when I was braking in my RS4 engine the transmitter stopped working and I lost control of the car and it hit the curb. After that I noticed the front of the chassis was bent upward at the front slightly. I didnt know if the chassis was made that way or if that was the result from hitting the curb. It hasnt effected the handling and performance any at all but I still wonder if the chassis was built that way going up slightly at the front. I dont know because I didnt pay attention to it until after I hit the curb. There was a problem with the transmitter it would cut in and out several times causing me loose control of the car. I had it sent off and repaired. Can anyone else with an RS4 3 tell me if the chassis come that way? I hope its not bent.
nitrous36 is offline   Reply With Quote
Old 08-13-2004, 11:16 AM   #2
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: RS4 3 Chassis Help
Well, it is now bent--sorry to say that. Better off with a new one, or else you can try hammer it back down to even. Good luck!
eddiethefish is offline   Reply With Quote
Old 08-13-2004, 11:25 AM   #3
Regional Moderator
nitrous36's Avatar
Its a very slight bend. You have to look close to see it. You sure the chassis isnt suppose to go up just slightly at the front?
Old 08-13-2004, 11:30 AM   #4
I had HPI before and yes, I once DID bend the HPI 2.5mm chassis. If you don't care about how the car really handles, it would be fine. But, then you'll have the tough time trying to setup the car to the way you want.
Old 08-13-2004, 11:48 AM   #5
Regional Moderator
nitrous36's Avatar
I can post a pic later so you can see and you look and decide.
Old 08-13-2004, 11:50 AM   #6
Also, you can try placing the bottom chassis against a level flat surface and observe if there is any gap along the chassis. If you see none, your chassis is fine, else, it's bent.
Anyway, look forward to seeing the pictures, perhaps others in the forum can help you, as well.
best,
Old 08-13-2004, 12:01 PM   #7
Regional Moderator
nitrous36's Avatar
I have just tested it on a flat surface like you said. Just before the front tires where the front bumper is mounted the chassis tapers up a little.
Old 08-13-2004, 12:11 PM   #8
Regional Moderator
nitrous36's Avatar
And I also held the car by the front bumper and was able to easily flex the chassis down to a flat position but as soon as I would let go it would go back up to its original position. This supports the idea that it came that way and that it may be bent. If I was able to flex it downard to a flat spot then it could have easily bent when it hit the curb. But when I let go and it returns to its original place that says it could of possibly came that way. When the car lost control and hit the curb it was going a little over mid speed and when it hit the curb it stopped it but it kinda rolled up the curb alittle. I think it was going about 20 something when it hit.
Old 08-13-2004, 12:22 PM   #9
Regional Moderator
nitrous36's Avatar
What version of the RS4 3 do you have?
Old 08-13-2004, 10:46 PM   #10
Regional Moderator
nitrous36's Avatar
Nobody knows?
Old 08-13-2004, 10:59 PM   #11
Moderator
Clegg's Avatar
no the chassis should be perfectly flat, if it isnt its tweaked.
I would got with a higher end chassis like the wolfpack radicals chassis or the HPI super chassis. they resist bending better. I personally would recomend the wolfpack radicals chassis.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
ESP Clodzilla IV Chassis for sale (Monster Truck Chassis) BloodClod R/C Items: For Sale/Trade 5 08-31-2013 08:48 PM
FS/trade TC3 Rolling chassis w/motor bodies and ESC w/extra chassis and extra's TC3guypgould R/C Items: For Sale/Trade 17 07-08-2007 02:00 PM
TAMIYA MSX fully loaded 3mm chassis, DJ pro module, full MS chassis Patriiick R/C Items: For Sale/Trade 0 12-19-2005 08:38 AM
Does the TC3 Graphite Chassis Kit come with droop screw adjustment arms and chassis? ixlr8nz Electric On-Road 4 04-13-2003 10:34 PM
1/12 trinity switchblade rolling chassis for sale/trade for 1/10 touring chassis largabaynus R/C Items: For Sale/Trade 1 03-03-2002 01:58 PM
