Vintage On-Road  Collectors Corner >
Like Tree48Likes
Old 01-29-2013, 04:17 PM
  #151
NytroNutz's Avatar
Originally Posted by lilchill
Wow some amazing cars on this thread...soon as I can figure out how to upload pics I'll post some of my reflex nt and gs sonic both are rollers sitting around getting dusty...well this has inspired my new winter project
Hey I have a ton of parts for the Reflex NT including a NIP main chassis. Let me know if you are interested [email protected]
NytroNutz is offline
Old 01-29-2013, 04:21 PM
  #152
NytroNutz's Avatar
Hey Lilchill - got Parts!! I have main chassis, suspension parts and other body parts. PM me
Old 01-29-2013, 04:43 PM
  #153
Default looking for
i am still looking for an old mclaren mk 6 or mk8 body or if you know of any company that is making some let me know need for a dynamic suspension shelf queen thanks
gomer3245 is offline
Old 01-31-2013, 12:50 PM
  #154
lilchill's Avatar
NytroNutz..yeah I'm looking for arms hubs spring sets clutchbell and gears minions and spurs...I'm new to the forums so trying to work out how to pm
lilchill is offline
Old 01-31-2013, 02:07 PM
  #155
Trader Rating: 29 (100%+)
Default restoring a bmt 95r Active...
Teamgimpy72 is offline
Old 02-01-2013, 07:30 PM
  #156
Default gettin closer
Old 02-03-2013, 10:33 AM
  #157
Default let the restoration begin....
Old 03-01-2013, 10:04 AM
  #158
Default bmt clutch bell bearings
anyone out there know the size of bearings i need for my 941 active's clutch bell? it is the blue one in the picture, the older bmt 2 speed bells in the picture are to large for the 941 and standard 5x10x4 bearings are alittle to big see picture, when i tap them in to seat them correctly the outside case of the bearing cracks. so im thinking a 5x10x4 flanged bearing might work but im unsure. as you can see i spent alot of money on the other clutch bell's only to find out they dont work with the car im restoring.
any help from any BMT old schoolers out there would help me out ALOT@@!!
Thanks JEsse
Old 03-04-2013, 12:20 PM
  #159
lilchill's Avatar
NytroNutz you get pm
lilchill is offline
Old 03-05-2013, 07:36 PM
  #160
NytroNutz's Avatar
Got it, sent you email!
Old 03-12-2013, 06:04 PM
  #161
Default rd logics mongoose
im 100% sure the RD Logic's "mongoose" is the same car, horizon hobbies should have all your parts on hand..
Old 03-12-2013, 06:15 PM
  #162
Default mcclaren body
i might have 1 up in the attic in a bag? not 100% sure,do you have a picture of the one your looking for? i will check this weekend.mike.
Mikiehotrod is offline
Old 03-12-2013, 06:31 PM
  #163
lilchill's Avatar
Default So Dusty
Finally got a couple pics up of my Trinity Reflex nt...need to go through it a get this dust off!
Attached Thumbnails Vintage On-Road  Collectors Corner-imag0517.jpg   Vintage On-Road  Collectors Corner-imag0514-2-.jpg   Vintage On-Road  Collectors Corner-imag0520.jpg
lilchill is offline
Old 03-12-2013, 07:17 PM
  #164
lilchill's Avatar
I actually have the mongoose and for the most part I can use spares from it, they just have slight differences but gears clutchbells bulkheads chassis radio tray fuel tank are all different from the Trinity "Reflex Nt". The arms hubs belts and side pulleys seem to be the only parts that interchange. Thanks though. How's it going with clutchbells bearing any luck finding the right size yet?
lilchill is offline
Old 03-12-2013, 08:48 PM
  #165
NytroNutz's Avatar
Hey Chilli here is what I have:
NT2153 3MM Chassis - 50.00
NT2061 Rear bulkhead - 9.00
NT2501 Solid Rear Axle - 45.00
NT2500 Front One-Way - 50.00
NT2083 Clutch Housing - 15.00
NT2085 1st Gear 18T - 7.00
NT2088 2nd Gear 21T - 7.00
NT2512 Aluminum Middle Belt Mount -30.00
NT2059 Bumper Set - 14.00
NT2509 Front Anti-Roll Bar Mount - 40.00
NT2121 Rear Arm Set - 10.00
NT2093 Clutch Nut Threaded Shaft - 8.00
NT2071 2 Speed Gear 47T - 7.00
NT2003 Front Upper Arm Shaft - 4.00
NT2077 Aluminum Pulley - 16.00
NT2011 Shock Piston O-Rings - 3.00
Plus some miscellaneous parts, arms, a bulkhead and some gears I will throw in for 20.00
