Old 09-27-2006, 08:33 AM   #841
devious17's Avatar
The XR8's rear lower arms are not adjustable to accomodate roll center changes, only the front is able to. Would adding shims to the bottom of the rear bulk do the trick ?
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 10-10-2006, 04:51 PM   #842
Post
I recently purchased a used XR/8 and looking for a manual. Is it accessible online anywhere? It doesn't appear to be on the Power Racing site. Thanks.
tmac is offline   Reply With Quote
Old 10-10-2006, 07:46 PM   #843
Trader Rating: 18 (100%+)
Default XR-8
I have a couple of the XR-8 manuals.
Send me your e-mail address and we can work out the details.
my e-mail is [email protected]
brc358 is offline   Reply With Quote
Old 10-10-2006, 08:25 PM   #844
Joehwee's Avatar
brc358: Care to share your setup and building experience with the XR8? What are the area to look out or do to make the car better.
Joehwee is offline   Reply With Quote
Old 10-11-2006, 05:13 AM   #845
Default XR-8
Would be more than happy to share my set-up.
I worked on the car for a couple of months to get it here, but the car handles fantastic now. I also have the new 2005 Evolva, and the XR-8 handles very close to the Evolva.
Anyway, here ya go.
Front springs white Mugen, 80 weight oil
Rear spings red Mugen 65 weight oil
Front toe out .5 each side
Front camber 2.5
Front caster all clips in the rear
Rear toe 2.5 to 3 toe in <I run a lot of toe in for the corners>
Rear camber 2 to 3
Roll center stock
Front tire 68 mm 40 to 45 shore
Rear tire 74 to 75 mm <I usually run a 6mm split> 35 to 40 shore
Mugen clutch shoe
Hardened clutch bell <stock aluminum ones do split into>
Airtronics throttle servo 737
Airtronics steering servo 358
Rex 321P engine
Novarossi 9886 pipe
New Kyosho Dome body <more down force>
I also drilled the top of the rear shock mounting hole about 1/8 lower on the shock tower
Once I worked out this set-up, the only changes I ever make to the car are the tires<shore>. I may drop down to 35 rear and 40 front depending on the track condition . This set-up is really working good for me. I have let a couple other drivers at the track that run Kyosho, or Mugen cars, and they cant believe the way this one handles.
Give it a shot on your car, and please let me know how it does. I would be very interested in how your car works with this set-up on different tracks.
good luck brc
Old 10-11-2006, 05:18 AM   #846
Default XR-8
Here is a pic of my XR-8
Old 10-11-2006, 05:30 AM   #847
Default XR-8
I forgot a couple of items
Front ride height 4.5
Rear ride height 5.5
I run "0" droop
Front sway bar set at 90 degrees
Rear sway bar removed <due to high traction bite at the track>.
I think this covers it all now.
brc
Old 10-11-2006, 09:22 PM   #848
devious17's Avatar
brc358, I notived your gurney flap is rather high up, doenst that create too much drag?
your XR8 dont run droop? the track must be very flat and smooth.
Audio,Video, Disco
Old 10-11-2006, 09:59 PM   #849
Default XR-8
The track I run on is extremly flat, very smooth, and high traction.
With this "Dome" body there is much more front down force than with my Protoform bodies. On my other bodies the Gurney flaps are approx. 1/8 to 3/16 of an inch high. This car did have a lot of push until I changed the set-up and started using this body. I have around 7 or 8 different bodies that are mounted differently, and the Gurney flaps set at different heights. I have tried quite a few different set-ups,and bodies and finally came up with this combination that works really well.
brc
Old 10-12-2006, 08:55 PM   #850
devious17's Avatar
Thanks brc, if I were to set this up with the protoform shell I'll need wheelie bars at the rear
our loal tracks looks smooth but it's not and with chicanes and tight bends requires different setup all together.
Audio,Video, Disco
Old 10-16-2006, 02:53 PM   #851
5iN
5iN's Avatar
Super noob question: Does anybody ever race 1/8th cars with regular sedan bodies anymore? All I see is can-am type bodies that don't really tickle my fancy appearance wise.
5iN is offline   Reply With Quote
Old 10-16-2006, 08:13 PM   #852
devious17's Avatar
Never seen anyone running a sedan shell on a 1/8 on-road yet
Audio,Video, Disco
Old 10-16-2006, 11:18 PM   #853
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Do they make 1/8 scale sedan bodies?
Wanabrc is offline   Reply With Quote
Old 10-17-2006, 04:51 AM   #854
Default XR-8
I think about as close as your are going to get to a sedan body would be the stock body that comes with the XR-80 RTR, or you might even try the body from Ofna for their new 1/7th scale car.
But as far as a 1/8 sedan body, I have yet to see one.
Old 10-17-2006, 06:39 AM   #855
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
lots of rear toe-in
Orfeous is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
