Old 07-02-2006, 02:42 PM   #826
Trader Rating: 18 (100%+)
Default PRP XR-8
Let me know how the new set -up works.
I have my dialed in great now, and if you need, I can send you my set-up.
My car hangs with the Mugens,Serpents,Kyoshos.
I am running the new OS version 2, 21, but now I think I will either change over to the Novarossi 35+21, or the new Rex 321P
I have the Rex 321P in my Kyosho 2005 Evolva, and the engine screams.
It does have more power than the OS 21, and with the XR-8 dialed in now, the car will handle the added power
good luck
brc358 is offline   Reply With Quote
Old 07-06-2006, 07:36 PM   #827
Originally Posted by devious17
the mugen stuff are indeed hardy but instead of shifting to all mugen I replaced the clutch bell for a ventilated serpent item and it worked great.
How to post pix? there must be an add attachment button somewhere, it's on the same page.Hope that helps.
Was wondering what steering servo's are you guys using. I am on the VX 13kg's and thought it could be an overkill, the VX's saps power from the Rx batteries.
I'm going to be doing that. The order has just been made.
I'm running Futaba 9451 upfront, and 3305 on the back. Works well with me. They are pretty good on batteries also.
Darthswan is offline   Reply With Quote
Old 07-14-2006, 04:26 PM   #828
Default XR-8
Picked-up new body from the painter yesterday, and not very happy with it.
Guess this one will be a practice body.
The new Kyosho "Dome" body is supposed to have more front down force.
Will take it to the track tomorrow, and give it a try
Old 07-21-2006, 03:35 PM   #829
What is size of the inner bigger bearing in the Centax clutch?
Old 07-23-2006, 09:49 AM   #830
Default XR-8
Tried to get the information for you, but the owners manual does not call out the size. You can call PRP direct, and they can help you.
The number is 408 988-1188.
They have been very helpful with me.
Old 07-23-2006, 07:55 PM   #831
I think I found it.
5 x 13
Old 07-24-2006, 09:51 AM   #832
duneland's Avatar
That's right. Same as Serpent.
duneland is offline   Reply With Quote
Old 07-28-2006, 04:46 AM   #833
Trader Rating: 93 (100%+)
Default Clutch
I just got the xr8. It has the dreaded aluminum clutch bell. I tried to put the mugen one on it but the gears don't line up. Will the gears line up if i use a serpent one and will the prp gears fit serpent bells. Thanks for any help.
latemodel13 is offline   Reply With Quote
Old 07-28-2006, 05:25 AM   #834
Default XR-8
Use the XR-8 gears on the aluminum clutch bell.
Keep checking the aluminum bell, as the do go bad. I know of several aluminum clutch bells that have gone bad. Mine actually slip in right in half. They also make a hardened clutch bell that is much stronger
Old 07-28-2006, 10:08 AM   #835
duneland's Avatar
The alum clutch bell is excellent in opperation but lacks durabillity. Just go ahead and use it, it will last for a while. As mentioned, PRP makes a steel one. I think the Serpent will work too, I will check later and let you know (I have both lying around).
Old 08-08-2006, 11:08 AM   #836
Cool
hi all, does anyone have the xr80 rtr? how is it for parkinglot bashing? and how does it compare to the schumacher gtr 1/8th scale car? i have a friend who has the schumacher gtr....thanks..
jinxjx is offline   Reply With Quote
Old 08-14-2006, 12:24 AM   #837
devious17's Avatar
I have been plaqued by this problem of the XR8 wanting to pull to the left side on a random occasion. Prior to this problem I broke both rear CVDs and was running on front wheel drive for a few minutes. I didnt want to stop in the middle of the mains so I continued on till I can no longer drive the xr8.
Was thinking could it be the front one way bearing been busted due to the fwd action? on power at random the car sill pull to the left sharply and at times it behaved as usual. Anyone with experience to identify a one way bearing fault?
I have checked the rest of the components on the car and couldnt find anything out of spec.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 08-14-2006, 04:14 AM   #838
Default XR8
Sounds like your front bearings could be binding up.
Also, the XR-8 just like the Serpents,Evolvas,and Mugens, need to have the front bearings,and the one way lubed on occassion. I have found the best oil for this is the Serpent one way bearing oil.
I use this oil on the rear one way on the rear shaft also, to stop the one way from slipping, and not being able to engage.
I am sure you know how, but you need to remove the front bearing,clean them, and then lube them, and while you are at it, clean and lube the front one way.
If your set-up is off from side to side <track width> the car will pull also.
Old 08-14-2006, 04:59 PM   #839
devious17's Avatar
Front bearings checked , cleaned and lubed with Serpent one way pinky oil, rear track width 265mm even on both sides too. anti-roll equal length and height, what else could be the cause..........
Chassis checked for tweek but none was found, Spektrum Pro re binded just in case. Wheels not warped but slightly chunked.
Will give it a go this weekend and if it still persist then I give up and will go for the MRX next
Audio,Video, Disco
Old 08-15-2006, 04:51 AM   #840
Default XR-8
I think I would then check your belts for slippage,and check you pullies for chipped teeth. Mine did this when I first bought it new, and the front pullie had about two or three teeth missing, and would only pull once in a while.
I changed it over to the Delta aluminum pullie, and have not had to worry about it.
I worked on my car for about 3 months fine tuning it, and getting to where it acts like it is on rails. The only problem I am having now, is I need to keep the rear one-way oiled, or it will slip. I spoke to PRP about this, and the Mugen MRX4 with work if I deceide to change over.
I took out the OS version two 21, and installed a Rex 321P a couple of days ago, and this thing is so much faster, it is unbeliveable.
The cars do have a couple of little quirks about them, and once you get them fiqured out, and know what to expect, they really can be very competitive.
good luck, and let us know how things work out.
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
