Old 06-28-2006, 08:54 AM   #811
Trader Rating: 18 (100%+)
Default PRP XR-8
Pic of my PRP XR-8 OS Version 2, 21, 9886 Pipe, 7 ring conical header,Airtronics 737 throttle servo, Airtronics 358 steering servo.
Mugen clutch,Mugen springs
brc358 is offline   Reply With Quote
Old 06-29-2006, 03:57 AM   #812
Has anyone gone back and changed there screws to steel screws?
Darthswan is offline   Reply With Quote
Old 06-30-2006, 10:03 AM   #813
hi guys i just would like to let all of you know i have an xr80 for sell or trade just check out the sell & trade thanx
team jhugg is offline   Reply With Quote
Old 06-30-2006, 10:27 AM   #814
Why are you selling or trading it?
Old 06-30-2006, 02:49 PM   #815
Darthswan i wanted to try and get into the onroad cars but wasnt for me i love the offroad so i will sell or trade for offroad looking for the old kyosho atv but might would let it go for an 1/8 scale buggy
Old 06-30-2006, 08:02 PM   #816
Default Clutch Bell disappeared???
Uhhhhh, it's in the title. I was running the car, and I hear some extra revving in the engine. I kill everything. Come to find out, the clutch shoe, carbon clutch shoes and bell are gone. Just like it was ripped off. I have to replace all of them. I can't describe it, i'm going to take a picture of it and post it.
Old 06-30-2006, 08:08 PM   #817
devious17's Avatar
It must be on the tracks somewhere. Could it be the Hex screw wasnt secured and worked itself out while running? Check cltuch bell gar so that it is not too much otherwise when the shoe kicks it kicks too hard.
Also look at your thrust bearings, I dont run any btw.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-30-2006, 08:27 PM   #818
Default PRP XR-8
I had the same problem with my XR-8
The aluminum clutch bells are prone to go bad.
Mine actually split in two.
They do have an upgrade clutch bell that works really well.
I put one on, and have not had any other problems.
You might want to also change the flywheel, fly weights,disc, and clutch pad.
I used all Mugen parts, and everything is working fine now.
Old 06-30-2006, 08:32 PM   #819
It just split. How do you post a picture?
Old 06-30-2006, 08:33 PM   #820
Did you use the complete mugen system?
Old 07-01-2006, 07:50 AM   #821
devious17's Avatar
the mugen stuff are indeed hardy but instead of shifting to all mugen I replaced the clutch bell for a ventilated serpent item and it worked great.
How to post pix? there must be an add attachment button somewhere, it's on the same page.Hope that helps.
Was wondering what steering servo's are you guys using. I am on the VX 13kg's and thought it could be an overkill, the VX's saps power from the Rx batteries.
Audio,Video, Disco
Old 07-01-2006, 08:29 AM   #822
Default PRP XR 8
I am using the Airtronics 737 for the throttle, and the Airtronics 358 for the steering.
I changed over the to the 7 ring conical header,and the 9886 pipe.
Also the front pully has been changed to the Delta. It is aluminum, and holds up great.
I am off tho the track right now with mine, but when I get back, I will take some shot of the car with the body off.
These cars are also prone to on-power push, but I found that if you use the Mugen front springs, 50 wt oil, and then use the Serpent body, the car really sticks well..
It took me about 3 weeks to get the car to where I wanted it, but I have not had to change the set-up at all, other than changing the tires for the track condition
Old 07-01-2006, 08:48 AM   #823
devious17's Avatar
I also noticed the push you mentioned but only when the front wheel are really worn down. I am still running the stock grey spring F/R with 40wt oil and Protoform shell.
Audio,Video, Disco
Old 07-01-2006, 03:56 PM   #824
Default PRP XR-8
Try the Mugen white springs, with 50 wt oil.
It should help take out the push.
Also if you go to the PRP web-site, look under XR-8 on the right side of the page, scroll down, you will see the set-up sheet used for Fort Myers in Florida.
I use most of that set-up, and then modified it for the track I run on.
Old 07-02-2006, 07:05 AM   #825
devious17's Avatar
Thanks brc358, will try out the white springs and 50wt damper oil .
Audio,Video, Disco
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
