Old 06-08-2006, 02:15 AM   #796
devious17's Avatar
Why is the Kfactory brake disc bigger than the disc on the XR8? I tried to intergrate the Kfactory disc into the XR8 but it didnt fit.
Shouldn't the 1/8's disc be bigger than the 1/10's ?
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 06-11-2006, 10:01 AM   #797
i want to buy the receiver case,but i don't know the exact number of this part,
please tell me which is this?
nefastseven is offline   Reply With Quote
Old 06-11-2006, 05:40 PM   #798
Trader Rating: 18 (100%+)
Default PRP XR8
The part number for the battery box is X81126
brc358 is offline   Reply With Quote
Old 06-11-2006, 05:44 PM   #799
Default PRP XR8
I listed the part number you needed, but called it a battery box, which in fact it is the receiver box. But the part number is correct.
Old 06-11-2006, 05:48 PM   #800
Default PRP XR8
Which engine do you have in you car. The photos are not too clear.
Is it the OS version 2, or a Serio.
Either way, do yourself a favor, ditch the stock header and pipe.
Pick up the new 7 ring conical header,and either the 9886 pipe, or the new Rex pipe.
You will see a big difference in the performance of the car.
Old 06-12-2006, 03:31 AM   #801
it's not my car
i have a serpent 960....i just want this receiver box,it's a good idea to have this one on a car....each manufacturer would do that
thanks fot the part number
look my signature.....you'll understand about my car
Old 06-12-2006, 07:50 AM   #802
Default Hello from Protech
For all VXR-8 drivers, you can mail me at Protech for setup sheets from our drivers and also ask for the new official Protech Racing Team setup sheet.
So if you are interested you can send your resulst to us and i will put them online.
Best regards,
Bart Loomans
Protech Racing Team
bart@protech.be is offline   Reply With Quote
Old 06-12-2006, 09:10 AM   #803
R40Victim's Avatar
I actually just lost a DSM reciever to a hard T-bone impact. I personally think that mounting location is a recipe for disaster, and ended up mounting the new one to the upper radio plate(safest place I could squeaze it in there). These cars are heavy, and the weight of the tiny reciever is insignificant; so a safe place is, in my opinion, far more important...
R40Victim is offline   Reply With Quote
Old 06-23-2006, 05:48 PM   #804
Anyone get the lower front machined arms? How are they? How much should you pay for them?
Darthswan is offline   Reply With Quote
Old 06-24-2006, 04:39 PM   #805
any help on getting stripped screws out? The screws to the engine block are stripped, so 1 i need to get them out and 2 get new screws. Any thoughts on the type of screws? Thanks in advance
K
Old 06-24-2006, 04:47 PM   #806
Originally Posted by devious17
check 3pk's throttle exponential, clutch spring , throttle linkage to ensure no slack.....these few items should remedy your hesitating responce problem.
hope that helps
I have fixed this problem, just had a engine shift. Damn accident
Old 06-25-2006, 02:54 AM   #807
devious17's Avatar
Happened to me too some joker on the track thinks it's a bumper car session.
Audio,Video, Disco
Old 06-25-2006, 07:39 PM   #808
Trader Rating: 93 (100%+)
Talking Great car
I'm new to 8th scale but bought an xr80 off e-bay and like it. I read on here some setup tips and they worked great. First i moved the rear shocks to the new location as posted on here. I also moved the rear body mount pivots to the outer hole and put the 3 mm of shims on the rear hub carriers. I would recommend anyone to try this and see if it helps your car as it really made mine work great. Stan
latemodel13 is offline   Reply With Quote
Old 06-25-2006, 08:56 PM   #809
Default PRP XR-80
If you go to Power Racings web-site, and look under the XR-8 they give a good set-up sheet that was used at Fort Myers.
I used it, and then modified it a little for the track I run on.
They way my car is dialed in now, I would compare it to the MRX4-R.
I also have the new 2005 Evolva, but the two cars drive completly different.
I did discover the the XR-8 car is prone to push a little. If you change to the Mugen white front springs, and then try the Serpent body, it really works great.
If you can ditch the stock clutch, and use the Mugen clutch
If I could post some pics. I would, but I can't seem to get my photos on the site.
Old 06-25-2006, 11:08 PM   #810
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
www.photobucket.com
Hey man it's me Sab from RCCA. Hows the 8th scene goin for ya?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
