Old 05-28-2006, 07:06 PM   #781
devious17's Avatar
to remedy early clutch engagement - tighten the clutch spring further , I am doing 0.8mm
If your second gear isnt kicking in release/loosen equally the clutch shoe screws furhter.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 05-29-2006, 07:31 AM   #782
Thanks for the info, sun went down yesterday before I can get it restarted. I'll let you know.
Darthswan is offline   Reply With Quote
Old 05-29-2006, 06:09 PM   #783
hey guys long time very long time..im looking to replace my xr80 prp motor with something else,
my budget is $300.00 bucks any suggestions?
what are you guys running in your xr8's?
epicbloodline is offline   Reply With Quote
Old 05-29-2006, 07:12 PM   #784
I have to go back and make an adjustment. The spacing between the clutch and the housing is to much. It is not catching. Any ideas on that one, i'm going to be working on it tonight.
Old 05-29-2006, 08:16 PM   #785
devious17's Avatar
the clearence between the clutch shoe and the clutch bell shouldnt be huge, The clutch shoe should just have about 1.0mm of play and should not scrub when you turn it.
If the clutch bell is too far out your clutch shoe wont last long..........and many other components in tandem. Hope this helps
Audio,Video, Disco
Old 05-30-2006, 08:15 PM   #786
pepsidawg's Avatar
Does PRP make more then the two spring options for the shocks (grey hard, yellow harder)? If they don't have any more options will other manufacturers springs fit?
Kevin Olson
pepsidawg is offline   Reply With Quote
Old 05-30-2006, 09:05 PM   #787
devious17's Avatar
you could try the mugens and serpents springs too. I am runing mugen's grey on 50wt.
Audio,Video, Disco
Old 05-31-2006, 04:41 PM   #788
Default How to get the spacing down?
Between last year and this year, I have done something that has increased the spacing. I'm curious how do you get spacing down. I have tried a lot of things, and they aren't working. Thanks in advance.
K
Old 05-31-2006, 07:09 PM   #789
devious17's Avatar
spacing?
Audio,Video, Disco
Old 05-31-2006, 07:18 PM   #790
Originally Posted by devious17
spacing?
Let me try and clear that up. The spacing between the clutch shoe and the clutch bell.
Old 05-31-2006, 08:09 PM   #791
I've fixed it. I have to make a couple of adjustments on my radio also.
Old 05-31-2006, 10:05 PM   #792
devious17's Avatar
oh! that one, yeah, you need to shim it to have the right freeplay between the shoe and bell. Too much will result in excessive shoe wear.
Audio,Video, Disco
Old 06-01-2006, 04:22 AM   #793
Trader Rating: 18 (100%+)
Default new engine
Right now, I am using the OS version 2 .
But three days ago, I ordered a new Novarossi 35+21 modified.
Car should really be dialed in then.
Everything else in te car is dialed in great, and then car is handling pretty much the way I want
brc358 is offline   Reply With Quote
Old 06-01-2006, 06:06 AM   #794
I'm going to be working on that this weekend. I was able to get the distance down, but from the time that I mash my 3PK to the time the engine accelerates seems to be a little delay time.
Old 06-01-2006, 09:11 AM   #795
devious17's Avatar
check 3pk's throttle exponential, clutch spring , throttle linkage to ensure no slack.....these few items should remedy your hesitating responce problem.
hope that helps
Audio,Video, Disco
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
