Old 04-28-2006, 09:38 AM   #766
R40Victim's Avatar
Wich "bits" are teflon? I'd like to upgrade my beasty, though I'm happy with the way it performs, I wanna have every advantage when I go up against the new 8th scale guys that come out to the track...
R40Victim is offline   Reply With Quote
Old 04-28-2006, 11:25 AM   #767
duneland's Avatar
The upgrade parts referred too are not teflon. They are machined from MC nylon, which is essentially delrin. The stock parts are equal to the parts from the other manufacturers. Stock clutch bell is aluminum & very trick. It does run a bit out of true after a while. I switched to the steel one offered by PRP, for durabillity reasons.
duneland is offline   Reply With Quote
Old 04-28-2006, 08:51 PM   #768
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Teflon arms, teflon 2speed shoe, hmm what else..?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-01-2006, 10:22 PM   #769
devious17's Avatar
my bad , MC Nylon indeed. I got the teflon stuck to my head due to work done on those material
took the xr8 out yesterday had some fun untill the rear carbon shock tower broke after being rear ended by fellow racer
Went to the LHS and got two of the same thing and CA them together. The aluminium shock tower is a little different in design, it's shock mouting holes are lower than the carbons.
Taking off the zip tie used to open the fuel lid. When the car turn turtle and is sliding the tarmac grabs the zip tie and opens the lid a little. if the O ring in the lid is set too tight the lid might not close after it is accidently open and looses fuel tank compression.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 05-03-2006, 04:18 AM   #770
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
as someone said.. "it really looks like that half is from serpent and the other from mugen"
is this a product with the best from serpent and mugen and put it to one car?
Orfeous is offline   Reply With Quote
Old 05-03-2006, 06:09 AM   #771
HarKonnenD's Avatar
It does look like both and performs great, but the only thing is they should have built it with teflon parts to make it stronger and then sell another version at the price of the other 8th onroad cars. Maybe call it the XR8-R Pro .
Old 05-03-2006, 06:20 AM   #772
Orfeous's Avatar
maybe they have thought of it
Old 05-03-2006, 06:47 AM   #773
HarKonnenD's Avatar
It's possible...but maybe if they had more of them at the big events and in the top 3 or something then maybe they might.
Old 05-03-2006, 10:49 AM   #774
captian's Avatar
there was a team at the last worlds running the car .the xr80 and other brands /slide / shepperd / mugen / serpent /kyosho
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 05-03-2006, 11:03 AM   #775
duneland's Avatar
devious,
One thing you might consider is changing the tank. I use a Kyosho tank on mine for 2 reasons; first, the stock tank is under-sized. Second, the Kyosho tank-lid has the cap lid angled up a bit, making it easier to get your thumb under. easier re-fuel.. A small amount of grinding is required on the upper deck to accommodate the new tank.
Old 05-03-2006, 12:00 PM   #776
Send a message via AIM to wagnerov Send a message via Yahoo to wagnerov
All of the XR/8 kits we have shipped out since late last year have a larger, 120cc tank. You can tell if you have the larger tank by the aluminum mounts either being 6mm longer than normal, or if the mounts came with spacers to move the tank up.
The Serpent tank also fits very well, with just a little bit of dremeling to the upper deck.
RCFIA.com - Northern California Formula 1 Racing
wagnerov is offline   Reply With Quote
Old 05-03-2006, 06:54 PM   #777
devious17's Avatar
Thanks Duneland, will keep the evolva's tank in mind. I just aquired the XR8 and would like to have a feel of the cars charactor before I make any changes to it.
How much ride height are you guys running? I have also been runing slam dunk 1/10 on our tracks and the 1/8 looked like they are 4WD on Lola shells
Audio,Video, Disco
Old 05-24-2006, 06:59 PM   #778
devious17's Avatar
Has anyone tried replacing the disc brake of the XR8? I thought I could use the Kfactory disc from my MTX3 but it seems the Kfactory bit is 2mm bigger than the stock single disc of the XR8.
I know the evolva's disc are compatible with the 1/10 disc.
Audio,Video, Disco
Old 05-25-2006, 01:20 PM   #779
Power Racing has an upgraded one-piece disc brake, part #X82018. I still like the stock brake disc(s) the most, though. It's lightweight and effective, kind of hard to beat.
Old 05-28-2006, 12:25 PM   #780
Default Clutch Adjustment
Due to a hectic work schedule, this is the first weekend I can fire her up. I went through and cleaned appropriately, but the clutch is engaging a lot quicker than it should be. Also, I can't engage the second gear. I need a little assistance. I know Duneland is one of the closest hobby shops to me, any closer. I would have to make a day trip out of it if I go out there. Thanks in advance.
K
Darthswan is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
