Old 11-23-2005, 02:47 PM   #721
ziggy12345's Avatar
Yeah I saw you can shim the track length back and was thinking of doing it. Ill prolly get the adj rear roll bar but will try it without for now. The weather is crap here so I will have to wait until it dries up
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-23-2005, 02:49 PM   #722
ziggy12345's Avatar
HORRAY!!
Sponsored by:
Norfolk and Chance
Old 11-24-2005, 02:40 AM   #723
ziggy12345's Avatar
I found the screw that holds the rear upper pivot pins in place. It screws into the back of the upper camber links!! DOH....
Cheers
Sponsored by:
Norfolk and Chance
Old 11-24-2005, 08:15 AM   #724
duneland's Avatar
Cool! I knew it was in there somewhere.
duneland is offline   Reply With Quote
Old 11-24-2005, 08:29 AM   #725
ziggy12345's Avatar
Somebody mentioned the fuel tank is smaller than 125ml so i measured mine, its 105mls!! Is there a larger one available?
Cheers
Sponsored by:
Norfolk and Chance
Old 11-24-2005, 04:50 PM   #726
duneland's Avatar
Yes it is small. I meant to mention that. I put a Kyosho tank in mine. Some of the guys at PRP use Serpent tanks. The Kyosho tank was on hand, so I used that one. It did not take to much time or trouble. Just a bit of grinding on the upper deck & and a little grinding on the plastic parts for the battery holder to get it to sit down as low as possible. While you have the dremel out, it is a good idea to remove a bunch of material from the inside/top of the rear bulkhead brace. That is the piece that goes across the very rear of the bulkheads. You will notice it has very little clearance to the rear belt/pulley. If any debris enters from the bottom, it can get wedged between that brace and the belt, causing dammage to belt. By opening it up, you allow any foreign particles to escape.
Old 11-25-2005, 02:15 AM   #727
ziggy12345's Avatar
Which tank is the least trouble to fit? Will the Serpent one drop straight in?
What track length do you run? I reduced it down as short as possible as I think I will need the steering. I also changed the shock pistons as it was packing off really quickly.
Sponsored by:
Norfolk and Chance
Old 11-25-2005, 12:16 PM   #728
duneland's Avatar
Do you mean wheelbase? If so, I run the shortest (front arms all the way back). I like lots of steering. It did not take much to get the Kyosho tank in. Just a few minutes worth of dremelling with sanding drum. I could not find any that drop in without modification of the upper deck.
Old 01-11-2006, 12:39 AM   #729
Regional Moderator
daniz24's Avatar
Which rim will fit to XR8? Thx
daniz24 is offline   Reply With Quote
Old 01-11-2006, 04:12 AM   #730
Serpent
hms racing is offline   Reply With Quote
Old 01-11-2006, 10:18 AM   #731
duneland's Avatar
Serpent, Mugen conversion available.
Old 01-22-2006, 12:19 AM   #732
Hey,
It's been awhile since I've dropped a message so....
Hope people are doing well, the weather in chicago is tricky, last weekend, running the car this weekend snow. I got my new radio and servos so I decided to install them. The 3pk is tight, got a 3305 on the throttle and 9421(i think) it's downstairs on the steering. The snow fell and I can't run it.
I have a question about the servo arm. Which one provides for better turning radius? A or B? I'm using a now and I'm trying. I'm working on a way to tighten the turning radius. The servo is quick, very quick, I like what I see so far.
Thanks for any response in advance.
K
Darthswan is offline   Reply With Quote
Old 01-22-2006, 11:11 AM   #733
duneland's Avatar
Not sure about radius. A & B are for different ackerman angles. Mainly, to tune the way the steering 'feels' in corners. The car is capable of making tight 180s, right around the end of a corner marker, with either selection.
Other factors also have a large effect on turn radius. Rear toe-in & Neg camber/tire cone, for instance.
Old 01-22-2006, 01:23 PM   #734
ziggy12345's Avatar
Hi
Just back from the track and my first outing with the XR-8. I ran a 35PLUS21 in it and it went really well, just as fast as anything on the track.
I changed the shock pistons to ones with bigger holes front and back and changed the oil to 35wt and removed the rear roll bar. The car was great!
I was pushing at the end and it was slightly damp and knocked the front offside corner off on the kerb. A new front bulkhead needed. Apart from that I couldnt fault it!
Its a winner!
Cheers
Sponsored by:
Norfolk and Chance
Old 01-22-2006, 03:20 PM   #735
Hello
ziggy12345 at end is a good car ? is fragile?
I live on Italy and think to buy one ,but want opinion from people to use it...
dragonal is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
