Old 05-18-2005, 07:59 AM   #406
Trader Rating: 74 (100%+)
Default RCX
Well guys, I cant wait to get out to RCX, and hang with Cameron, and Rog...
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 05-18-2005, 08:00 AM   #407
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Default Re: RCX
Don't stop short goon, your going to break your nose....
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 05-18-2005, 08:17 AM   #408
Default stuck
hehehehehe
Old 05-18-2005, 08:30 AM   #409
goon, when are planning to race 1/8th on-road again? Stop wasting time farming.
Old 05-19-2005, 01:32 PM   #410
R40Victim's Avatar
Farming... Are you guys smokin that Wacky Tobaccy?
R40Victim is offline   Reply With Quote
Old 05-19-2005, 01:33 PM   #411
Default farming
Carl, when I get back a couple of weeks after that.
R40, no wacky tobbacky for me!!!!
Old 05-19-2005, 01:39 PM   #412
R40Victim's Avatar
Well, due to the rain out during the first 8th scale heat, in theory, we'll do make-ups this Sunday. During the mayhem, my fuel presure lead came off the tank, and the engine leaned out (didn't overheat to my supprise), and it was signifacantly quicker. I may be able to get even more speed out of this thing...Can't Wait!
Old 05-19-2005, 03:00 PM   #413
CD3 RACING's Avatar
Send a message via AIM to CD3 RACING Send a message via MSN to CD3 RACING
R40 How do you like the XR80?Ive been thinking about it just because its all there.
CD3 RACING is offline   Reply With Quote
Old 05-19-2005, 08:34 PM   #414
R40Victim's Avatar
Yes, it's a nice car, however, the assembly of the RTR had several flaws. The body, rear droop adjustments, springs, caster, camber, 2-speed, you name it, all wrong. It was thrown together. Mine was among the 1st to get here, the wing wasn't even mounted on the body.(it was crap) The later shipment that I've seen have all had wings installed, and the bodies were fitted better. Not sure but it looks like they're working out the bugs. It's a good handling car, I'm very impressed with it.(my 1st 8th scale car) You just can't beat the price. It even comes with a starter.(the leads on wich are reversed, or they accidently put the wrong colors on each) The engine is doing well so far, no flame outs. It's breaking in nicely, getting a little quicker each run. I'm already on my 3rd set of fronts, and 2nd set of rear tires.(25 shore rear, 35 shore front) The rear spool is initially confusing if you don't know what to expect. It turns in harder on throttle, so to rotate the car, you hit the gas. We run on what is a great sized 10th scale track, so it feels small with these cars. It's also rather tight/technical, so the balistic speeds these things will go, don't quite happen in a small space. Overall, I like the car, can't wait till the next race.
Old 05-20-2005, 12:50 AM   #415
M7H
M7H's Avatar
Originally posted by R40Victim
.....my 1st 8th scale car....
Oke, it's your 1st 1/8 car, no wonder it's impressive .....
25 Shore!
is this normal for you guys, here we drive 35 shore as softest......
normally I drive 35 or 37/38 front and rear.....
Serpent
M7H is offline   Reply With Quote
Old 05-20-2005, 07:50 AM   #416
duneland's Avatar
We run 35's here as well. Perhaps they equiped the XR80 with sorfter tires to hook-up better on un-prepaired surfaces. It being a RTR means most owners will bash rather than race.
duneland is offline   Reply With Quote
Old 05-20-2005, 07:59 AM   #417
duneland's Avatar
My XR8 is done! Went together quite well & finished product is excellent! Only a couple of issues; clutch nut internal threads were a bit goofed up (took a bit of work to get the threads cleaned up enough to get my flywheel installed). Supplied set-up sheet is terrible. I would like to have a completed setting sheet with tire diameters toe settings, oil, springs, etc.
That aside, I like many of the features better than my Evolva! I hope it drives as well.
Time to get packed for Ohio! Will find out, tomorrow, how well it works.
Old 05-20-2005, 09:32 AM   #418
R40Victim's Avatar
I always start with as sticky a tire as I can get. Then, I start tuning, unless it proves unwaranted.(bad push, way loose, it depends) When it was cold I would run 35F and 30R on my pro-4. I would've done the same with my R40, but it just eats rears, so I usually end up running 35R and 40F. The tires that came with the XR80 are very soft, softer than the 25 shore I bought...we didn't know they got that soft
I wore out the stock fronts in about 3 races worth of driving. When I put new Jaco 35s on the front, it got way loose. So I replaced the rears(25 shore), BINGO!, it hooked up. I'm still experimenting with the suspension settings, ect...
THere was supposed to be an Evolva there on that last raceday, but he didn't make it. It was the same evolva we compared to the XR80. Like I said, very few differences...
Old 05-20-2005, 09:46 AM   #419
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I always like running a lil softer shore in the rear. Makes the car hook up better under acceleration and turning.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-20-2005, 10:39 AM   #420
R40Victim's Avatar
Same here, although, recently, as the track temps rise, I've actually switched to running 35s all the way around on my Pro-4. My pit partner actually runs the opposite, softer up front.(NTC3, and a TC4). He also runs harder shore as well, generally everything over 40. Sometimes he'd run 30mm in the front, and 35mm in the rear. He can't be too wrong, he's one of the best drivers out there, very consistant. If it weren't for my "taking chances kung fu style" I'd never get by him...
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
