Old 02-19-2005, 09:12 PM   #256
Great customer service. So I could complete the back axle, I moved the bearings to the back and I will put the others up front. Chassis is looking good i'll post some pics later.
Kevin
Darthswan is offline   Reply With Quote
Old 02-20-2005, 12:03 PM   #257
Perez's Avatar
Thumbs up
I saw one of these run the other week at a club race at the RAMS track. At first the driver had some problems with the clutch but when that was worked out the car looked good!
Perez is offline   Reply With Quote
Old 02-20-2005, 12:12 PM   #258
Did you know what type of clutch problems?
Old 02-22-2005, 01:52 PM   #259
Nitro Tech
dino.tw's Avatar
Evolva's Rear Shock Tower
dino.tw is offline   Reply With Quote
Old 02-22-2005, 01:53 PM   #260
Nitro Tech
dino.tw's Avatar
another picture
Old 02-22-2005, 01:55 PM   #261
jag
jag's Avatar
Originally posted by dino.tw
another picture
Is that a Kyosho sway bar as well?
jag is offline   Reply With Quote
Old 02-22-2005, 01:58 PM   #262
Nitro Tech
dino.tw's Avatar
No. I took it from my MRX2.
Old 02-23-2005, 04:58 PM   #263
Send a message via AIM to wagnerov Send a message via Yahoo to wagnerov
No need for Evolva parts. You can drill holes in the stock shock tower. Note that the new holes we are using are 10mm above where the tower mounts to the bulkhead. Doing this requires a spacer (we used a 3mm nut) behind the plastic shock mount, and taking a little material off the edge of the tower to allow the shock to pivot freely. We asked the manufacturer to add this to future releases of the XR/8.
RCFIA.com - Northern California Formula 1 Racing
wagnerov is offline   Reply With Quote
Old 02-26-2005, 12:31 PM   #264
how are you supposed to put the wheels on it?
i have just built two of these cars, and the axle shafts are bigger in diameter than the holes in the wheels!
does this mean i will have to drill out every new set of wheels that i get?
also, why are all of the suspension parts brittle, hard plastic instead of nylon?
anrkii is offline   Reply With Quote
Old 02-26-2005, 01:15 PM   #265
jag
jag's Avatar
The wheels are very tight but they will go on. I finally got mine all the way on after working them on and off for some time. I put a set of Ellegi's on it and they fit perfectly.
Old 02-26-2005, 01:24 PM   #266
jag
jag's Avatar
I am having clutch problems as well. I cannot get the clutch to fully engage. I have it setup as the directions say but they don't say how tight the nut on the spring should be. I have tried it at .5mm and 1mm. Maybe the 710 clutch nut is causing the problem. Oh well, back to the drawing board.
Old 02-27-2005, 02:17 AM   #267
so why drill or change the rear shock tower? are the stock holes in the wrong location?
also, the stock rear sway bar looks really iffy, anyone tried the upgraded one yet>?
Old 02-28-2005, 02:52 AM   #268
Suspended
Besides the engine/pipe/radio, what else is different between the RTR and Kit versions?
THanks
403forbidden is offline   Reply With Quote
Old 03-01-2005, 02:58 PM   #269
I think it's a case of the wheel hole being too small, rather than the axle shaft being too big. It is a quality control problem on Enneti's side, not ours. In all honesty, we went through 25-30 sets of Jaco and Enneti tires at the Winternats, and not a single one was tight...oh well.
Jag: I'm guessing that you might have too much end play in the clutch bell. Try setting the clutch with .5mm between the top of the clutch nut and the adjuster. Then shim the clutch bell so that there is only 1-1.5mm of side-to-side movement. Make sure the 4 clutch shoes are between the flywheel pins, not over them. It should be heavy with that setup.
The "clutch problems" mentioned at the race above were user error...he put the bearings in the clutch bell incorrectly. The two ball bearings go into the clutch from the inside...he put one on the outside and one on the inside like most 1/10th cars. He's all set for the race this weekend!
And the plastic parts are nylon. All companies like to use a different composite percentage to achieve different goals.
Old 03-01-2005, 05:28 PM   #270
revzalot's Avatar
Make sure you have a good caliper to shim the clutch correctly. Two most important things to know about 8th scales are the clutch and the two speed tranny. Both are crucial for proper launching. On a small track you may want to adjust the clutch to engage much sooner while longer straight aways will require slower engagement. Don't forget to lube the thrust bearings every 30-45 minutes of track time. I like adjust the clutch first then the tranny.
revzalot is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
