Old 02-16-2005, 06:57 AM   #241
Suspended
Originally posted by jag
He told me they were waiting for the shipment of cranks and it would be 7 to 10 days. He told me that last thursday.
i talked to him on monday...he said that the cranks should be here at the end of this week....choco
SERPENTFREAK69 is offline   Reply With Quote
Old 02-16-2005, 06:24 PM   #242
My kit came in the mail today. Brooklyn Hobbies, they all right with me. Now the fun part putting it together. Any special tricks or hints to pass on????
Kevin
Darthswan is offline   Reply With Quote
Old 02-17-2005, 07:47 PM   #243
Maybe I'm a little slow, I've been doing well with the directions, but what is up with the braking system? Do you peal off the back of the and affix it the back of the other pad? It's slowed me. Thanks in advance.
KLS
Old 02-17-2005, 08:41 PM   #244
revzalot's Avatar
KLS
KLS, I don't have my kit yet but I've worked on my S950. I would sand the ends and use CA or shoo goo to glue them together. You would not want the brake pads to come off during a race. What other stuff did you find trivial?
revzalot is offline   Reply With Quote
Old 02-17-2005, 08:58 PM   #245
The directions have the 2 brakes outside of the disc. These directions are not good at all. I also noticed that I was short 2 ball bearings, so i'm trying to find out how i go about getting these bearings. It was easy up to this point. ARG
Thanks for the info,
Kevin
Old 02-17-2005, 09:23 PM   #246
revzalot's Avatar
Kevin
Any bearing shop would do as long you have the right dimensions.
Old 02-17-2005, 09:30 PM   #247
InitialD's Avatar
Maybe somewhat unrelated to XR8 but you could get the 9607 Race brake pads for the 950R together with the 9606 brake discs. No fade and they are pre-bonded. Recommended upgrade.
Old 02-18-2005, 01:11 AM   #248
Nitro Tech
dino.tw's Avatar
I'm using the Mugen's yellow brake pad. Juat affix(replace) it with the new pad.
If you want change the brake discs,use Hobao GPX4 optional discs. It works find on XR8 without any mod.
dino.tw is offline   Reply With Quote
Old 02-18-2005, 04:10 AM   #249
Since my appointments are on the light side today, I'm going to stop by the Hobby Shop. I need to pick up some X81002, kit was short 2. My wife doesn't know I order my engine, so we'll see how that goes.
Kevin
Old 02-18-2005, 06:42 AM   #250
jag
jag's Avatar
KLS
I peeled the backing off the pad and stuck it to the metal plate... one for each side of the brake disk. Like a sandwich. The brakes seen to rub a little but once the car is driven I think it will be fine.
jag is offline   Reply With Quote
Old 02-18-2005, 07:03 AM   #251
I'm sitting here waiting for the hobby shop to open, so I can continue my mission. The lack of bearings slowed me down.
Need those before I can continue with the brakes
Old 02-18-2005, 10:48 AM   #252
Send a message via AIM to wagnerov Send a message via Yahoo to wagnerov
The brake pads will drag a little bit on the first run of the car. The belts will also be tight at first, so if the drivetrain feels draggy when you're done building the XR/8, don't worry about it...the car will come into its own. Some people sand their pads before running the car for the first time. No need to CA them to the calipers...my car has about 2 gallons through it with the same set of pads using the adhesive backing. They're kind of worn though.
I think I am going to try the Mugen pads at the next race. I know we have some of our own upgrade pads on the way from Taiwan soon, but they won't be here in time.
Darthswan, if you're the one who emailed Roger earlier today, you've got some bearings on the way. If not, well, let us know and we'll take care of it!
Thanks,
-Cameron
RCFIA.com - Northern California Formula 1 Racing
wagnerov is offline   Reply With Quote
Old 02-18-2005, 10:54 AM   #253
revzalot's Avatar
Wow! Cool customer service.
Old 02-18-2005, 12:17 PM   #254
Roger's Avatar
Yups, just mailed out the bearings right after receiving your e-mail
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 02-19-2005, 09:06 PM   #255
jag
jag's Avatar
Default Clutch
I found that using a clutch nut from a Serpent 710 works perfectly on the Mega ZX21 with the Mega collet. I also used .5mm of shim behind the collet but that may be too much as I did not need to use any shims to set the clutch gap. I also used a 3x15 screw in lieu of the 3x12 the instructions call for.
My car is now completely assembled and I hope to run it tomorrow if I can get it to fit on my startbox.
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 06:12 PM
