Old 08-11-2004, 12:02 PM   #1
Default Centax-1 & Centax-2
I recently acquired a Veteq 2002, which uses a Centax-1 clutch (albeit with the newer screw-on gears). I would like to use a Centax-2 clutch as I like the larger bearings and different clutch shoes. It seems that the pinion gears are the same from one clutch to the other.
My concern is with the transmission spur gears... they are still original gears that are used before the new LC-II gearbox.
Can anyone tell me for certain whether or not I can use the Centax-2 clutch with the original transmission gears (pre LC-II) ?
GlennCauley is offline   Reply With Quote
Old 08-11-2004, 12:19 PM   #2
Glenn, the gear pitch is the same, but the spacing between gears (1-2) is different between the new style 2-speed and the older original one. You would need to change out the 2-speed shaft and use the newer transmission to use the new Centax II.
John Patterson is offline   Reply With Quote
Old 08-11-2004, 01:15 PM   #3
PSI Racing's Avatar
John is right, you're going to have to get the new 2 speed and shaft if you want to use the Centax II.
901611 Layshaft-2SP LC Veteq
902410 2-speed gearbox LC
PSI Racing is offline   Reply With Quote
Old 08-11-2004, 02:56 PM   #4
Default Centax-2 and LC-II tranny
Hmmmm... I already have the new tranny in my 835, so all I would need would be the 901611 layshaft it seems...
I wonder if the benefits of using the beefier Centax-2 are worth the trouble of changing anything... opinions?
Old 08-11-2004, 04:37 PM   #5
PSI Racing's Avatar
I'm still running my Veteq 02.
I haven't switched to the new gear box yet.
This link might help you.
http://www.mytsn.com/forums/forum.as...lo=1&sm=0&fi=1
Check out Luc Goemaere post under LC gearbox upgrade.
CENTAX CLUTCH Nikonianmike Nitro On-Road 5 08-31-2008 06:51 PM
WTD....centax 2 and LC gearbox 6Cuda6 R/C Items: Wanted to Buy 1 09-08-2004 07:12 AM
Centax Clutch nitrodude Nitro On-Road 20 01-17-2004 08:42 PM
Who's got a centax clutch? XER987 Nitro On-Road 3 03-22-2003 03:25 PM
A centax that uses AE gears? Jon Carlson Nitro On-Road 5 11-14-2002 10:07 PM
