XRAY Composite Receiver Case
XRAY Composite Receiver Case XRA336000 Any one know the inside Dimensions in mm of the Receiver Case ? and from one screwdriver to the other on the top??
Thanks |
your up Drew
Originally Posted by jjrctech
(Post 8530282)
Thanks May I ask way you need this? I can measure it for you to see, but I just sent off Ralph's car and the parts to Fort Myers. Will check it when I get down there. Thanks Drew |
(Post 8530282)
Thanks From 1 screw to the other (that goes on the radio tray). The distance is 57mm.. The inside width of the box is 20mm. The total height of the box (right underneath where the radio tray should sit) is 16.5mm. The average length inside the box is 51mm. I can assure you its big enough to fit a Spektrum micro receiver and a new personal transponder. Hope this helps. |
I got a Futaba rx in there with wires and a power switch! Whatever you got can't be bigger than a Futaba rx.
Originally Posted by Riketsu
(Post 8532393)
The inside width of the box is 20mm. The total height of the box (right underneath where the radio tray should sit) is 16.5mm. The average length inside the box is 51mm. I can assure you its big enough to fit a Spektrum micro receiver and a new personal transponder. Hope this helps. Thanks for the info |
Originally Posted by Drew Ellis
(Post 8532347)
Thanks Drew |
Originally Posted by jrice
(Post 8532722)
does this mean i get to be the first to see the new car?????
Thanks Drew |
