Old 08-10-2004, 04:42 AM   #1
Quietroit's Avatar
Default pinch test for the low end needle
How do you pinch the fuel line gentle or try to pinch the engine fuel line enough to cut the motor off. I need your help please tell me the right way how to do the pinch test for the low end needle.
Thank you
Quietroit is offline   Reply With Quote
Old 08-10-2004, 07:04 AM   #2
Ybakoff's Avatar
You need to squeeze it hard to stop the fuel from going in, the motor should run for about 10 sec.
Ybakoff is offline   Reply With Quote
Old 08-10-2004, 02:09 PM   #3
Trader Rating: 15 (100%+)
Send a message via AIM to James Y
i adjust mine so that it only runs for 2-3 seconds.
James Y is offline   Reply With Quote
Old 08-10-2004, 08:19 PM   #4
esham's Avatar
Check this out..
Pinch Test - 01
Pinch test -02
Mine, 4-5 second before it off. Lower than that i believe its too lean.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-11-2004, 05:10 AM   #5
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Originally posted by esham
Check this out..
Pinch Test - 01
Pinch test -02
refer to PINCH TEST 01... it says... pinch near the carb.
refer to PINCH TEST 02... somebody said... in the middle.
so... esham and james-Y... where did you PINCH your tube?
middle of the tube or near the carb?
logically.... pinch NEAR the carb... coz if your tube is LONG... then you pinch in the middle.... means you will have MORE fuel to burn. if you pinch NEAR the carb nipple... it doesnt matter how long your fuel tubing....
am i correct?
and emmm... thanks for the link esham!!!
mop
mop_iko is offline   Reply With Quote
Old 08-11-2004, 09:59 PM   #6
GrandeGixxer's Avatar
mop, i agree. as close to the carb. 4-5 sec. just be careful if using needle nose like i do not to pinch and cut the line against the nipple of the carb
GrandeGixxer is offline   Reply With Quote
I need advise on pinch test/tunning... Mpowerz Nitro Off-Road 28 01-16-2008 01:36 PM
RE PINCH RACING MASON Nitro Off-Road 11 10-30-2007 08:00 AM
Pinch Test Danie Onroad Nitro Engine Zone 7 06-20-2007 12:08 AM
Engine Tuning/Setup 101 (sealing and pinch test) Kemorc Onroad Nitro Engine Zone 0 06-06-2007 11:37 AM
Middle Needle or Spray Bar Needle tuning tips? FACTION95Si Nitro On-Road 12 12-22-2001 02:33 PM
