Old 01-15-2011, 12:44 PM   #1
Jake C6R's Avatar
Default Installation Question Re NTC3 Backing Plate for Non Pull Start
Hi all,
I am converting my .12 AE to non pull start. I have a question regarding the installation of the non pull start backplate.
The diagram I am looking at shows the non pull start backplate going into the engine the same way as the pull start backplate did. Which means the oval part of the backplate with the indentation on top (same shape as the pull start back plate) goes inside the engine. However, if it is installed this way, the end of the backplate hits against the connecting rod. Am I doing something wrong here? It looks to me like the only way it can go is with the protrusion on the backplate installed toward the outside of the engine. Or maybe it doesn't matter anyway as long as it is a good seal?
If you want to see the diagram I am looking at it is here on page 4:
http://www.teamassociated.com/pdf/ca...ngman_2912.pdf
Thanks!
Jake C6R is offline   Reply With Quote
Old 01-15-2011, 12:51 PM   #2
nitrodude's Avatar
You're going to have to cut of the "niple" thats on the end of the rod journal on the crankshaft.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-15-2011, 12:57 PM   #3
Jake C6R's Avatar
Thanks Nitrodude. I how do I get it out to cut it off? Sorry, never taken one apart before.
Old 01-15-2011, 01:14 PM   #4
nitrodude's Avatar
Dremel with cut-off wheel
Steven Muller
Ronin Speed Parts
Old 01-15-2011, 01:33 PM   #5
Jake C6R's Avatar
I can do that but can you tell me what the steps are to get the piston and connecting rod out so I can cut it? Thanks!
Old 01-15-2011, 01:40 PM   #6
nitrodude's Avatar
Remove the cylinder head and combustion chamber.
Remove sleeve.
Remove piston with conrod(they come out together)
Remove complete clutch from engine.
Pull crankshaft from engine and cut.
Steven Muller
Ronin Speed Parts
Old 01-15-2011, 02:13 PM   #7
Jake C6R's Avatar
Remove sleeve.
Thanks, Bro! I'll give it a shot now.
Old 01-15-2011, 03:09 PM   #8
Jake C6R's Avatar
Hey Nitrodude, thanks again! That was easy as pie and I'm already done - worked like a charm.
I was a little nervous having not taken one apart before that I would screw it up, but I just followed the steps you gave me and there is nothing to it!
Thanks for taking the time to help me out.
