Old 01-10-2011, 04:13 AM   #1
Default problem with sirioxxxv
hi guys have sirio xxxv 12 engine and 3 pipes which can i used nov2630 mega2607 or misslepipe
mileage is offline   Reply With Quote
Old 01-10-2011, 05:43 AM   #2
I would use the 2630.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 01-10-2011, 09:01 PM   #3
Default can i run the sirio xxxv out of the box
hi can i run the sirio xxxv out of the box it says 10 tanks was put through and it is track ready
Old 01-11-2011, 11:18 AM   #4
stefan's Avatar
Send a message via AIM to stefan
The 2607 comes closest to the 2653 Sirio pipe, so I would use it.
Short pipes don't work well on Sirio's.
stefan is offline   Reply With Quote
Old 01-11-2011, 12:37 PM   #5
el salvador's Avatar
Exclamation
If I'm not mistaken, the 2607 is a Picco pipe, and the Manifold Inside Diameter is too small to fit the Sirio Exhaust Port.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 01-11-2011, 05:55 PM   #6
I would first turn it over by hand to determine if you would run it as if it were new:
If you can pop it over and it doesn't feel like there is a metal to metal contact, just really good compression, then I would run it slightly rich 2 tanks and then go balls-out!
But if it feels like there is a pinch near TDC, then run it rich for 5 tanks or so until you can feel it richening up and when you feel that the pinch has lessened.
