Old 08-05-2004, 03:47 PM   #1
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
Default Possible Air leak? HELP!
I have an HPI 12 R SS engine that is acting strange, what happens is when I gun it it runs great and when I let the throttle go back to neutral or brake it has a high idle until I turn the wheels? I ran it and looked at the carb, the boot on my rotor carb had bubbles coming from it, could this be an air leak? It is about 1 year old so I guess it could be an air leak.
TIA
Smoke21 is offline   Reply With Quote
Old 08-06-2004, 11:44 AM   #2
Smoke21's Avatar
ttt
Old 08-06-2004, 12:25 PM   #3
tomkelley's Avatar
Some people use air seal on all the fittings, and boot. I'm not sure what the boot is designed to do, either to keep dirt out or keep air from leaking. Other things you could do is replace the orings on the needles, might need to buy new needles to do that.
I ended up using teflon tape around the carb fittings, and even wrapped teflon tape around o rings above the needle threads. You can check this by blowing on the carb and air leaks should be minimal. You'll have to put your finger over the exhaust to do this, but it shows you where air is leaking.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
air leak mjnp06 Onroad Nitro Engine Zone 3 10-08-2007 10:59 PM
Air leak help Mustang2 Electric Off-Road 1 10-29-2006 01:35 PM
I think I have an air leak? Dishy Nitro On-Road 1 06-26-2006 04:38 AM
Nova Rossi engine Air leak or fuel leak? Solara Nitro On-Road 15 01-21-2005 04:00 AM
Is it a leak??? hicheef Onroad Nitro Engine Zone 1 06-28-2004 01:49 PM
