my engine slevee is struggling to slide through the crankase what should i do
Hi people I'm struggling to slide my engine slevee into my crankase what should I do now?
Heat the Block & Freeze the sleeve, Elimentary Science class!!!! When it cools it'll be snug to a tight fit. Freeze the Sleeve the night before.
Just oil it up (the sleeve) and heat the case up. I had an incredibly tight fit once, this made it so much easier.
Only it might be a nightmare to get it out in the future.....
I always use a scotch brite pad or waterproof sandpaper to wrap it arround the sleeve and turn the sleeve arround with my finger, it will make it a fraction smaller.
Getting it out WILL be a PITA, I know because even though I used the zip tie method, after many times of cutting the tie, I did eventually get the sleeve out but later found a gouge mark in the piston side - but it was serious enough to do any damage, I just made sure nothing was protruding off the edge.
