Old 12-28-2010, 06:30 AM   #1
Default my engine slevee is struggling to slide through the crankase what should i do
Hi people I'm struggling to slide my engine slevee into my crankase what should I do now?
kyoshoevolvam3 is offline   Reply With Quote
Old 12-28-2010, 12:28 PM   #2
gfilos's Avatar
heat the crankcase a little bit with a heat gun, and the sleeve should
drop in easily.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 12-28-2010, 09:30 PM   #3
Geezatec's Avatar
Heat the Block & Freeze the sleeve, Elimentary Science class!!!! When it cools it'll be snug to a tight fit. Freeze the Sleeve the night before.
Geezatec is offline   Reply With Quote
Old 12-29-2010, 02:09 AM   #4
Just oil it up (the sleeve) and heat the case up. I had an incredibly tight fit once, this made it so much easier.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-29-2010, 03:51 AM   #5
M7H
M7H's Avatar
Only it might be a nightmare to get it out in the future.....
Serpent
M7H is offline   Reply With Quote
Old 12-29-2010, 04:07 AM   #6
Roelof's Avatar
Send a message via ICQ to Roelof
I always use a scotch brite pad or waterproof sandpaper to wrap it arround the sleeve and turn the sleeve arround with my finger, it will make it a fraction smaller.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 12-29-2010, 07:19 PM   #7
Getting it out WILL be a PITA, I know because even though I used the zip tie method, after many times of cutting the tie, I did eventually get the sleeve out but later found a gouge mark in the piston side - but it was serious enough to do any damage, I just made sure nothing was protruding off the edge.
