Old 12-27-2010, 08:45 AM   #1
Default need help my engine slevee is to tight to go inside block does it need replacing
need help my engine slevee is to tight to go inside block does it need replacing.Im goin to replcae the piston and slevee but thething is by replacing the slevee will a new one be much easier to slide in the block? Also ive removed the pin that possitions the slevee becausethe top of the pin meleted for some reason but is there any way of putting a new pin inside and how can i replace a new poin were can i get these from.
thanks people
kyoshoevolvam3 is offline   Reply With Quote
Old 12-27-2010, 10:46 AM   #2
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Maybe you overheated the motor?
Wanabrc is offline   Reply With Quote
Old 12-27-2010, 11:13 AM   #3
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
First, if its a Picco, this is normal. Picco's have a very tight fit. I always have to heat the block to remove them.
The pin "melting" is more a concern to me. I have never even heard of that. What makes you think it melted? Are you sure it didn't get damaged when the sleeve was removed or installed?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-27-2010, 11:18 AM   #4
I promise the.pin is out now is there any way of getting a new one or would I have to go to a hardware store to get a pin any suggestions.
Old 12-27-2010, 11:28 PM   #5
You could leave it out, but it's highly recommended that you have the pin there so the sleeve doesn't manage to rotate itself during use, though I would think that the odds of that happening are nearly impossible because of how it is all held down.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-27-2010, 11:36 PM   #6
The odds of getting a new one is pretty slim. I would try and find a piece of piano wire you could use.
Old 12-28-2010, 12:59 AM   #7
Wanabrc's Avatar
+1 I normally heat up the block using a hair drier
Old 12-28-2010, 06:22 AM   #8
RipModz's Avatar
Default pin
Use the back side of a drill bit
RipModz is offline   Reply With Quote
Old 12-28-2010, 10:30 AM   #9
Sleeve locating pin.
OFNA Part number 51303
How many threads are needed on this subject?
D Starks is offline   Reply With Quote
