Old 12-27-2010, 06:58 AM   #1
ugglasdav's Avatar
Default Velox V8 2 speed
hey guys, have abit of a problem with the 2 speed in my velox v8, the c clip that has to go on the end of the bar, but the bar seems to be to short as i cant fit the clip, would anyone know wat is causing this?. also is the bearings on the second gear suppose to be normal or flanged ones and does one go on ethier side? many thanks
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 12-27-2010, 08:45 AM   #2
ND
Hi
Try loosening the pulley of the opposite end of the 2 speed shaft, then move the shaft so you can fit the e clip on the gearbox end.
With regards to the bearings they are flanged and go either side of the 2nd gear housing
Cheers
Neil
ND is offline   Reply With Quote
Old 12-27-2010, 12:16 PM   #3
ugglasdav's Avatar
cheers neil, i got it sorted in the end
>>>Sanwa m11x
Shepherd Velox V10 occ Nitro On-Road 1453 08-16-2016 10:34 PM
Shepherd V8 '09 Josh Cyrul Nitro On-Road 400 10-13-2011 07:09 AM
