tune pipes
tune pipes
I am looking for a good tune pipe to fit a mugen msx3 with a MV12 in it. The car has the same layout as the FW05R. It will need do be coupled by a silicon joiner
This is the opposite to most cars as the pressure line is on the opposite side or the stinger. Looking for a pipe that will give good performance.
Thank you If anybody happens to know of any others could you please post as well .
I will have to do some research as to which pipe is best.
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
pipe pipe pipe... how about stinger? hehehe
talking about pipe.... i would like to share with all this cool thread.
http://www.rctech.net/forum/showthre...939#post878939
guess it owuld give some interest.
mop
mop
I think the best .12-,15 tuned pipe of all time are the Novarossi 51603, Rex 51613, Top 51612, and the RB X12 Turbo which basically all are (top end) high speed pipes.
Just realized none of the pipes I have listed above will work on your nitro car because your pipe is mounted on the right side sorry....
question
is the shark pipe ok?
or what pipe can you recommend that is good and durable?
You also need a pipe that is suited to your engine ie the kyosho pipe is awsome on the kyosho GS-15R but might not be any good on a NSR.
Looking for one to go with the MV12 it is a pull start engine very similar to the pull start novarossi.
