Old 12-26-2010, 05:53 AM   #1
bluer322's Avatar
Default Sirio power clutch
The sirio site is under construction, im tring to find out were can i get one from.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 12-26-2010, 06:12 AM   #2
blackyblackman's Avatar
Hi!
Its the same like Capricorn clutches...!!!
Its the same manufacturer, i think!
Greets,
Black
blackyblackman is offline   Reply With Quote
Old 12-26-2010, 06:33 AM   #3
bluer322's Avatar
Originally Posted by blackyblackman View Post
Hi!
Greets,
Black
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-26-2010, 06:37 AM   #4
DS Motorsport's Avatar
Hi!
Greets,
Black
The Sirio and Capricorn clutch aren't the same and aren't made by the same manufacturer!!.
The WCE 2010 Capricorn clutches are better then the Sirio clutch.
With the WCE clutch you can use your own pinions instead of having a lot of trouble getting some Sirio pinions.
Also the red capricorn shoe is better then the sirio shoe, it gives more low end punch and is less critical on setup.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-26-2010, 07:01 AM   #5
The WCE 2010 Cap clutch is awesome. I'm using it on my 966 and I have to say that it's the best 1/8th clutch I have ever used. The red shoe last forever, lightweight, easy to adjust and has great punch. They are available for MRX-4/5 and S966.
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
[email protected], www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 12-26-2010, 07:02 AM   #6
you can use kyosho pinions on both clutch systems i have found
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 12-26-2010, 07:22 AM   #7
bluer322's Avatar
I spoke to someone from Serpent/Desto racing last week. I was told early Jan. They should have them in, I want one before the Winter Nats.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-26-2010, 07:46 AM   #8
Originally Posted by bluer322 View Post
I spoke to someone from Serpent/Desto racing last week. I was told early Jan. They should them in, I want one before the Winter Nats.
We have them in stock already including shoes and parts.
Desoto Racing
Old 12-26-2010, 09:37 AM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
I can be wrong but when you get the right parts for your current clutch you probably will end up with a same clutch.
Most standard clutches come with a setup which will work but can be improved a lot with only a different shoe and a harder spring. Personally I do not see an extra value for all the other parts.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 12-26-2010, 09:52 AM   #10
Try it and you will be convinced.
Everyone who I spoken to who had tried the Capricorn clutch said it was the best clutch they ever had. Build it correctly and you have it dialed in within 5 minutes.
P1-RC.com
Old 12-26-2010, 10:01 AM   #11
RoyalPalmRacer's Avatar
Trader Rating: 27 (100%+)
will the Xray pinions fit on the Cap clutch? just wondering
Sean B.
#86
RoyalPalmRacer is offline   Reply With Quote
Old 12-26-2010, 10:15 AM   #12
bluer322's Avatar
Ill call again Monday, Do you have a part number.
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-26-2010, 10:22 AM   #13
The Xray pinions will fit the Capricorn WCE 2010 for NT1 clutch.
P1-RC.com
Old 12-26-2010, 11:43 AM   #14
Roelof's Avatar
Explain to me the difference in flywheel, pressure plate, flywheel nut, steel clutchbel and bearings, no real difference to me. As mentioned before, the most difference is made with the spring and shoe and I know many do experiments with the flyweights.
Old 12-26-2010, 02:14 PM   #15
lil-bump's Avatar
Trader Rating: 83 (100%+)
Does the Cap clutch work with the 733 WC pinions??? Last I checked it does not.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
