Old 12-26-2010, 03:27 PM   #16
DS Motorsport's Avatar
Explain to me the difference in flywheel, pressure plate, flywheel nut, steel clutchbel and bearings, no real difference to me. As mentioned before, the most difference is made with the spring and shoe and I know many do experiments with the flyweights.
I agree, the most difference is made by the spring, shoe and flyweight combo. Get this matching perfectly and the other parts have little influence.
And this is just the thing Capricorn has done very well, the spring, shoe and all other parts are matched very well to have a perfectly working package.
You will also save some weight compared to the stock clutch, and as you might know saving just a couple of grams on the clutch equals, let's say 10-15 grams in the differential because of the internal ratio.
Originally Posted by lil-bump View Post
Does the Cap clutch work with the 733 WC pinions??? Last I checked it does not.
Pass you soon...
Which clutch did you use to check, the 733 WCE 2010 version?.
I will have to check it to be 100% sure if the WC pinions fit the 733 WCE clutch.
I do know the Serpent WC pinions fit the Xray bell and thus the Capricorn NT1 WCE clutch.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-26-2010, 03:43 PM   #17
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The Kyosho Shimo clutch and the sirio clutch are very similar, if not the same. I know the Sirio clutch shoe fits the Shimo clutch as I tried the sirio shoe on my car at the Nebraska Roar Nats.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-26-2010, 05:22 PM   #18
The flywheel is a smaller diameter AND lighter, the shoe angle is different so you get more surface area, it comes with 2 spring, 2 shoes...
part# CAP 468 WCE for S966
475 WCE for MRX-4/5
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
[email protected], www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 12-26-2010, 05:29 PM   #19
lil-bump's Avatar
Trader Rating: 83 (100%+)
I've seen the sales AD for the Cap clutch for the 733; and it says only works with the original pinions. I assume this does not mean the WC pinions.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-26-2010, 05:36 PM   #20
I've seen the sales AD for the Cap clutch for the 733; and says it only works with the original pinions. I assume this does not mean the WC pinions.
Pass you soon...
Ok, I will look into this as I want to know this as well.
But the WC gearbox and pinions are fitted to the 733 as standard right?.
If this is the case I'm pretty sure the clutch will fit, but I will check it with Capricorn.
P1-RC.com
Old 12-26-2010, 07:57 PM   #21
lil-bump's Avatar
For the 720 it was an upgrade to the WC gears. For the 733 It was stock.
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-27-2010, 02:47 AM   #22
hello everyone........
<a href="http://www.kraftseeds.com">Buy Seeds Online India</a>
<a href="http://www.mahajanconveyors.com">Transmission Rubber Belts</a>
<a href="http://www.vikrantholidays.com">Shirdi Tour Packages</a>
<a href="http://www.helpessays.com">Assignment Help</a>
avgadvertising is offline   Reply With Quote
