Old 07-20-2014, 06:47 AM   #991
dj apolaro's Avatar
I will look tonight when I have time to go through my stuff and will let you know.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 07-20-2014, 11:59 PM   #992
gsxr0311's Avatar
Trader Rating: 19 (100%+)
DJ, your not going to make it to the Novarossi challenge?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 07-21-2014, 05:12 AM   #993
British Menace's Avatar
DJ Apolaro
Thanks DJ. Much appreciated.
PS: You were missed at the Byons this year. All the best for the rest of the season sir.
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-21-2014, 06:08 AM   #994
dj apolaro's Avatar
Regards
BM
The inner part of the shock is 10mm and the outer is 12.9mm.
Yeah, I tried to go, but the flights and everything were just not convenient with my work I had.
Shame too, looked like some good racing.
DJ Apolaro
Old 07-21-2014, 06:10 AM   #995
dj apolaro's Avatar
Can not make it. I have other races that conflict with the Nova Race. Have fun though!!!!!! It is always good racing the Greater LA track.
DJ Apolaro
Old 07-22-2014, 09:36 AM   #996
DJ Apolaro
Thanks DJ
Old 07-22-2014, 07:52 PM   #997
gsxr0311's Avatar
DJ Apolaro
Now who's setup am I going to copy? LOL, just joking.
Old 07-25-2014, 01:13 PM   #998
GMartinez's Avatar
Trader Rating: 85 (100%+)
Default Feeler Lab C801 WC Mint
Has less than 30 min on it including break in
this was the previous version before the black edition
has the reverse clutch roller no electronics $400 shipped
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 08-30-2014, 09:54 AM   #999
Default Clicking noise from the rear end of the drive train
Dear all,
i have a clicking noise on the rear end of the driver, actually it seems that its coming from the disc brake area.
I have tried replacing the 2 x bearings of the 2 spd shaft and i also replaced the ones at the back where the solid axle sits.
Problem still not solved
Tried removing some tension from the rear belt and it helped but you can still hear the clicks and drive train is not butter smooth.
When the belt is removed the 2spd shaft runs very free and even the rear solid axle is free.
Nothing is touching belt is new and gears are quite new.
With one whole 360 degree rotation from the 1/2nd gears shaft you end up hearing like 6-8 clicks
Thanks in advance
speed6 is offline   Reply With Quote
Old 08-30-2014, 04:21 PM   #1000
I had a similar problem.
Try to replace the z20 pulley and his support on the 1/2nd gears shaft .
I seems that you have to much play between the support and the pulley.
Replacing only the z20 pulley will help a little.
crashnco is offline   Reply With Quote
Old 09-02-2014, 02:51 PM   #1001
Check to see if the layshaft pully is not touching the bulkhead, if the pully is to close to the bulkhead the pins holding the disc can rub on the bulkhead.
Shepherd is offline   Reply With Quote
Old 09-02-2014, 04:35 PM   #1002
Inspected these parts and found some play between pulley and support. Tried putting some silicone to fill in the gap. Will try it tomorrow.
Old 09-08-2014, 02:07 PM   #1003
It worked the clicking noise was coming from the play between the plastic Kevlar gear and the holder.
thanks crashnco
Old 03-23-2015, 11:59 AM   #1004
pioupiou's Avatar
Guys,
I'm rookie...
One question about the right position of the body on CAP C801 Collari Edition.
I have an used body (i don't know which reference is?). The distance between the front of the body and the bumper is 14mm. I think it is too on the rear!?
Now i bought a P909 body. Which is the right position? I red something about 25 mm? I'm perplexed.
Is it normal to have this gap according the type of the body?
Is it possible to adjust the position of the body in base of the track? Which is the common range to adjust the body?
laurent
pioupiou is offline   Reply With Quote
Old 03-23-2015, 11:04 PM   #1005
RC-Netshop.dk's Avatar
Originally Posted by pioupiou View Post
Guys,
I'm rookie...
laurent
I would say 14mm is fine, and I would only in rare cases go further than 14mm. You know that the body posts are eccentric? So depending on which way they are set now, you can move the body a bit to the front or rear. You can use this for fine tuning if you have a little to much steering, move the body backwards and vice versa.
Yes, moving the body back or forth can be used as a set-up tuning depending on the track you run. But I would find a standard position that suits me, and only turn the body post for fine tuning when needed. Rest of the tuning I would do on the car set-up.
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
