Old 03-24-2014, 03:24 PM   #961
Just starting to build the new 801 and does any one have the default setting for the servo saver post position and setting for the new servo saver (ackerman) as these items are not mentioned in the set up sheet
Shepherd is offline   Reply With Quote
Old 03-24-2014, 05:01 PM   #962
DS Motorsport's Avatar
Start out with the middle hole and the 11 insert.
Personally I ended up with the servosaver all the way forward and the 12 insert.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-24-2014, 11:43 PM   #963
Thanks for the reply, forgot to mention that this is the new chassis with four holes for the servo post
Old 04-16-2014, 04:43 AM   #964
MRX4XXXX's Avatar
Hello all,
Where can I find a starting setup for the new reverse-clutch??
Meaning:
- Spring tension?
- Bell-clearence?
- Gap?
-X-
MRX4XXXX is offline   Reply With Quote
Old 04-16-2014, 08:11 AM   #965
speedracer1bp's Avatar
Originally Posted by MRX4XXXX View Post
Hello all,
Meaning:
- Spring tension?
- Bell-clearence?
- Gap?
-X-
spring tension .5 mm
Bell clearence .7 mm
Gap .1 mm
This works excellent with super hard spring
Wallace Motorsports, WRC, DeSoto Racing, Matrix Tires, Nuggets Ranch Raceway
speedracer1bp is offline   Reply With Quote
Old 04-17-2014, 01:56 PM   #966
MRX4XXXX's Avatar
Gap .1 mm
Thanks!!! I'll start with that.
-X-
Old 04-23-2014, 03:19 PM   #967
JamesHealey's Avatar
What updates has the C801 Pro 2014 car had, also how does it compare to the Black version?
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 04-23-2014, 03:30 PM   #968
Managed to find the info out by having a good browse through the Capricorn website!
Old 05-08-2014, 02:59 AM   #969
Hi everyone I'm building an new car. I have some new rsx one10 servos will these be strong enough to do the job. my current car is using futaba 9451 from memory they were around the 9kg mark. or should I grab a rsx2 response hc I'll be running a lipo too thanks
Regards shaun
monaro is offline   Reply With Quote
Old 05-08-2014, 02:27 PM   #970
Regards shaun
The RSX One10 servos will do fine, I used them in my C801 as well.
P1-RC.com
Old 05-08-2014, 06:15 PM   #971
gsxr0311's Avatar
Trader Rating: 19 (100%+)
as do I and they are awesome.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 06-02-2014, 10:05 PM   #972
Send a message via MSN to Gianni Giorgio Send a message via Skype™ to Gianni Giorgio
Time to work on my 1/8 c 801 !!!! Next race ay homestead Florida on road challenge june 21/22
Capricorn LAB C801 1/8 scale-image.jpg
Mugen Racing/Matrix tires /Mikedesigns/VP fuel
Gianni Giorgio is offline   Reply With Quote
Old 06-02-2014, 10:10 PM   #973
Working in my c801 !!!! Clean and clean lol
Old 06-17-2014, 08:36 AM   #974
Harold996tt's Avatar
Originally Posted by DS Motorsport View Post
Small update regarding my 2012 car.
Pretty much completed the car, only waiting on the new clutch which should be available within 2-3 weeks.
Fitted the rear flex system, I'm very interested what this does on the track.
Also drilled two additional holes just in front of the radio tray supports, these will be used to mount weight. Right now it looks like the car will weigh around 2350g so I needed some extra spots to mount the weight.
Wondering if anyone actually felt a difference using the rear flex system. Any feedback appreciated.
Capricorn C802 1/8 GP, Mugen MGT7 1/8 GT.
Nostalgic collector of old Rc junk.
http://www.tamiyaclub.com/showroom.asp?id=44535
http://vintagerccar.blogspot.sg
Harold996tt is offline   Reply With Quote
Old 06-18-2014, 09:49 PM   #975
gsxr0311's Avatar
I have tried the car with the rear flex system and without the rear flex system but with the top deck screws loose. I couldn't tell a difference. I imagine its to keep the top deck from lifting if the screws happen to back out, but I'm not sure.
