Old 04-03-2013, 03:20 PM   #826
Originally Posted by dj apolaro View Post
Hey Guys,
Sorry for the reply with my 1/8 scale set-up, just been really busy. Some racers have been asking me so here it is. My car was actually really good, but the results to not show that. I has a car with good steering and was able to keep good speed in the corners. My fast lap in quals where 14.7-14.8, not sure at the moment. My issues was having to pit or we could have competed for the TQ. If I missed anything on the set up or it is confusing just ask.
What I did that is not on the sheet.
-ran the front with flex radio tray.
-ran the rear with flex as well
-ran the front upper arms with no shims under
-I used the new bar in the front with the stiffer one (I think it is 1.4)
Thanks,
DJ Apolaro
DJ, the new front bar offers
1.2
1.3
1.4
1.5
1.6
The stiffest 1.6 due to the Dia of the rod seems on par with the softest 1.3 old bar
Do you think the same also or not? interested to hear your thoughts on the new front bar setup.
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 04-04-2013, 10:08 AM   #827
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Lightbulb help
so do you guys setup your car to the tire size 68/75 for practice and then when the qual comes around the tires are good or do you initially start with a lower size tire? i saw dj's setup but im wondering if im waisting tire if i start at 67.5/74 just to practice before a qual? thanks
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 04-04-2013, 10:17 AM   #828
dj apolaro's Avatar
1.2
1.3
1.4
1.5
1.6
I feel like 1.6 is a little stiffer than the old 1.3. With the 1.6 my car felt better from left to right with the reaction. I did not feel like I lost much of anything in the middle though. Maybe just a hair in the middle, but the reaction gain was very noticeable.
I like the newer system just because it is easier to adjust.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 04-04-2013, 10:20 AM   #829
dj apolaro's Avatar
I try not to adjustment my ride height. If the car starts to get to low, I change the tires. If you do adjustment the ride height, then you have to adjust the droop since that will change. If you tighten the shocks down to get back ride height the car will have less roll and be more flat, since you take away travel in the chassis. I start with the 74/67.5 for the warm up and go with that. Then just put new tires for the next race.
DJ Apolaro
Old 04-04-2013, 11:45 AM   #830
gsxr0311's Avatar
Ok. At what point do you discard the tires, 72mm rear? Thanks dj.
Old 04-04-2013, 11:48 AM   #831
dj apolaro's Avatar
I think the left rear would get down to about 70 or 71 and it was fine. No lowerbthan that though.
DJ Apolaro
Old 04-04-2013, 12:08 PM   #832
gsxr0311's Avatar
Ok. Thanks so much.
Old 04-04-2013, 12:20 PM   #833
When I say matching I mean 74/67.5, 75/68.5 ect ect
For me if i dont have any old tires to practice on say 71,or 72 or 73 rear sizes with matching fronts. I will cut a new set to 75 with matching fronts
For qualifying I like them 75-73 range and matching fronts
Never adjusting ride height I will try to set the car for the main and just leave it
My tire rotation for club races normaly works like so
starting with no used sets
New set for practice and round 1
New set for round 2 and 3
New set for main
Following week
used set for practice from week before from main, or from rounds 1 or rounds 2/3
Sometimes I can run round 1 on a used set from the week before
round 2/3 and main new set
This gets me to 2 sets per club raceafter the first weekend.
I normally care less about round 1 at a club race because the track will be far better in 2and 3.
At toledo I can run my tires down to 68 rears if I have to.
A normal 2 day race.
Used for practice
new for round 1, then 2
new for round 3
used for round 4
main 30mins if wear is low cut new to 74 if its high 76
32 fronts/35 rears
Hope that info helps
Old 04-04-2013, 02:39 PM   #834
gsxr0311's Avatar
yes that helps. 68 rear wow. thanks guys.
Old 04-04-2013, 02:42 PM   #835
Our track is smooth, and pretty med to high traction
You can run 1/12 scale cars on it
Old 04-05-2013, 12:43 AM   #836
js058515's Avatar
This is good info, thank you for sharing.
New set for main
Following week
Used for practice
new for round 3
used for round 4
32 fronts/35 rears
js058515 is offline   Reply With Quote
Old 04-05-2013, 03:47 AM   #837
DS Motorsport's Avatar
Finished my custom receiver box:
Need to make some small changes to the design (too thin in some spots) but the overall fit and finish is very nice. The 471 receiver from Sanwa fits perfectly.
Now that I know the minium wall thickness and design features of the material I will start with the design of the universal receiver box for the standard Capricorn cars.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-08-2013, 11:39 PM   #838
has anyone got details on how to set up the reversible clutch, used it for the first time this weekend and suffered from dusting on the yellow clutch shoe
Andy
Shepherd is offline   Reply With Quote
Old 04-09-2013, 02:37 AM   #839
RC-Netshop.dk's Avatar
Andy
Hi Andy,
Some of my customers and drivers have experienced the same problem. This weekend (6-7 of April) I made a brand new reverse clutch for my C801 and tested it. Didn't have the slightest dust from the yellow clutch shoe. But what I do the first runs is to have no tension on the spring, to run in the clutch shoe first. The first run I use 2-4 tanks.
After that I gradually tighten the clutch spring in 0.2mm and normally I end up around 0.8mm - 1.00mm with the spring in the set. Depending on the traction that day. Because at the moment the season is just begun here in Sweden/Denmark and the traction changes a lot with the temperature changes. Saturday we had sunny wheather with 8-9 degrees celciuos in the shade and ok grip. But Sunday sunny with changing wheather and 5-7 degrees celciuos and no grip.
When I get time I can give you the rest of my measurements on the clutch if you like, just send me a mail.
Thanks,
Niko
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 04-10-2013, 09:13 PM   #840
Almost ready for this season to start here in the midwest
Capricorn LAB C801 1/8 scale-photo-1-.jpg
