Old 02-14-2013, 10:25 PM   #796
GREGORY!'s Avatar
Daan?how this concept is going?
Originally Posted by DS Motorsport View Post
For some time I've been working on an electric conversion for the C801E.
I really like the concept of an electric 1/8 but until now all the offerings can't really match a nitro 1/8. I hope I can change this and come up with an electric car which can actually beat the nitro powered version over a 5 minute run!.
I'm using a completely new motor and esc system which has been developed specifically to use in a 1/8 onroad.
I've been working for more then a year on a conversion based on this system, as a base I will use the Capricorn LAB-C801.
Here some renders:
It took a while to get the correct carbon fiber for the chassis, I finally have the type I want and all the carbon fiber parts will be finished this month.
I would really like to know how you guys think about this!.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 02-15-2013, 03:12 PM   #797
DS Motorsport's Avatar
I'm currently waiting on an updated version of the motor/esc to arrive. This will combine the motor and esc to one unit and this gives a lot more room for the batteries. This will probably need a new radiotray design and maybe even a new chassis.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-16-2013, 05:27 AM   #798
GREGORY!'s Avatar
How many Watts are we talking about?
Old 02-16-2013, 09:15 AM   #799
4000 watts
P1-RC.com
Old 02-16-2013, 10:03 AM   #800
GREGORY!'s Avatar
4000 watts
Aiaiaiaiai!!
Smoken!
Old 02-26-2013, 07:56 AM   #801
P2gee's Avatar
Quick question for everyone about a issue I'm having with brakes on the C801. I can have the brakes set and working well at the start of a main, but about half way thru say a 30 minute main they become grabby and more aggressive spinning the car out at every corner. I have played with radio and linkage settings thinking I had a problem there but it really seems the more the pads warm up the more aggressive they become. Anybody else run into this and come up with a solution.
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
P2gee is offline   Reply With Quote
Old 02-27-2013, 01:42 AM   #802
RC-Netshop.dk's Avatar
Hi,
I haven't had the same problem. But maybe it's because I use the Mugen blue brake pads. I just cut them so they fit nicely.
Could be a solution, if you try them. As I said I don't have that problem.
Br,
Niko
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 02-27-2013, 06:06 AM   #803
Could be that since wheels get smaller the brakes become more powerful if you are using them to the almost locking limit when new, than its for sure the case.
happens to me but adjust it with ATL from the remote, half way through the race I decrease it whilst in pits.
speed6 is offline   Reply With Quote
Old 02-27-2013, 07:47 AM   #804
P2gee's Avatar
Originally Posted by RC-Netshop.dk View Post
Hi,
Br,
Niko
Thanks for the tip and I think you are on to it. After taking the brakes apart it appears the standard pads are made from the red rulon material similar to the red clutch shoe. Thinking back several years, on a previous car, I made some brake pads for it from a left over rulon clutch shoe and had results similar to what I'm have with the Cap now. I guess all the properties that make Rulon a great clutch material make it a lousy brake material.
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
Old 03-14-2013, 05:38 PM   #805
Finally found the time to complete my C801 in order to sell it.
You can find it here:
http://www.rctech.net/forum/r-c-item...l#post11931484
If someone wants additional info just let me know.
P1-RC.com
Old 03-26-2013, 06:10 PM   #806
gsxr0311's Avatar
Trader Rating: 19 (100%+)
hello, can someone tell me the roar minimum weight limit on 1/8 car is this car under weight?
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 03-27-2013, 09:36 AM   #807
dougday's Avatar
It probably is underweight. The ROAR minimum is 2450g coming from 2525g
dougday is offline   Reply With Quote
Old 03-27-2013, 09:45 AM   #808
This was mine, completely stock with regular servos, lipo battery and regular weight body:
So make sure you've got some weights ready to mount onto the car.
P1-RC.com
Old 03-27-2013, 10:57 AM   #809
gsxr0311's Avatar
ok, thanks guys.
Old 03-28-2013, 08:41 PM   #810
I use the stock brake pads
one thing that could be happing is tire wear, not brakes, as the tires get smaller in the main the brakes have a bigger mechanical advantage over the wheels and tires. making it seem like they get "stronger"
I adjust mine on pit stops during a main, example lets say my car is dialed in with a end point of 65 for max brake before the car might over brake and lock up, each pit stop I may have to reduce it 1 point or 2 points near the end.
This is just how I do it, others may be able to just adapt, I find it no big deal and have a button on my radio set just for this.
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
