Old 03-27-2012, 08:32 PM   #631
DS thanks for all the info.
Not knocking your work on the throttle ok as I realise that you have to do that to get it to work and I will have to do the same thing.
But that is disgusting, we pay $700 for this kit which is rather expensive and we have to make an abortion on the throttle linkage.
If anyone here knows someone at Capricorn, tell them it's disgusting, how hard would it make to put a hollowed out area in the corner of the fuel tank to clear the carb slide.
Cheers and thanks for the info.
Clinker42 is offline   Reply With Quote
Old 03-28-2012, 05:46 AM   #632
we use in this way
Capricorn LAB C801 1/8 scale-foto.jpg
CapricornRC is offline   Reply With Quote
Old 03-28-2012, 05:47 AM   #633
Old 03-28-2012, 05:48 AM   #634
Old 03-28-2012, 06:19 AM   #635
dj apolaro's Avatar
I use the same way as shown in these photo's.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 03-28-2012, 07:01 AM   #636
RC-Netshop.dk's Avatar
Default Capricorn Denmark, Sweden and Norway
Hello Everybody,
I just like to inform you that you can purchase Capricorn products from my 2 shops rc-netshop.dk and Ebay store Kangaroo-Company...
At the moment rc-netshop are down for maintenance but will be up and running soon.
I have the distribution of Capricorn in Denmark, Norway, Sweden and also sends world wide. Also the distribution of Orcan and JP GIMAR engines for Denmark...
But anyway I got a big stock of Capricorn products and its still getting bigger , if you need something you dont find in the shops, send me an email at nikolaj(at)rc-netshop.dk or sales(at)rc-netshop.dk and IŽll help you... We do have products still not inserted in the shop...
See you on the track
RC-Netshop.dk is offline   Reply With Quote
Old 03-28-2012, 08:02 AM   #637
Default Capricorn Lab C801 1/8 NIB
Awesome priced
http://www.ebay.com/itm/140731871141...#ht_500wt_1287
spdmkr is offline   Reply With Quote
Old 03-28-2012, 12:08 PM   #638
xtremes's Avatar
Originally Posted by CapricornRC View Post
3
This is the same way I have it set up and I have not had any problems with it...
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 03-28-2012, 12:32 PM   #639
I have tested the M3 fuel tank and it works good. You only have to enlarge the back hole of the tank by 1mm.
Another advantage of the M3 tank is that he has more place for the steering servo so it is easier for the servo arm.
The bottom of the tank is 3mm higher than the original, better for the accu, but the weight of the fuel (or gravity center of the tank) is also higher.
Capricorn LAB C801 1/8 scale-dsc_0072_cmp.jpg
crashnco is offline   Reply With Quote
Old 03-28-2012, 05:42 PM   #640
Well I will admit when I'm wrong.
Capricorn, the way you have yours is fine, it looks good and works well.
I will try mine out today.
But I think maybe Capricorn have changed some things on the kits at some stage because there is a few things on my kit don't fit like on some of the other guys pics on here.
Old 03-28-2012, 06:08 PM   #641
DS Motorsport's Avatar
I agree the solution shown by Capricorn looks a lot nicer. I decided to mount the throttle rod from the bottom because it makes it easier to reach the low speed needle with still the body on the car. Don't want to loose time in the pits with my mechanic fiddling around to reach the lsn.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-28-2012, 06:21 PM   #642
xtremes's Avatar
What is it you find does not fit correctly in the car ? I might be able to help you with it.....:-)
Vidal
___________________
Old 03-28-2012, 08:00 PM   #643
P2gee's Avatar
Question. Is there any way to adjust the angle of the front upper arm brackets for active or non-active caster??
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
P2gee is offline   Reply With Quote
Old 03-29-2012, 12:09 AM   #644
Dasmopar's Avatar
Send a message via AIM to Dasmopar
3
I am in the middle of my build and I am having trouble getting the pinion gears to line up with the spur gears. I see your picture is much closer to being inline with the same motor. Did you do anything to get the gears to line up flush with each other? It looks to me like my motor could be moved to the passanger's side about 1mm. I have made use of all the slop in the motor holes already.
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 03-29-2012, 12:51 AM   #645
Dasmopar's Avatar
Never mind I figured it out. I didn't have the 2 speed shaft bearings seated 100% in the plastic inserts.
Lon Burling II
