Capricorn LAB C801 1/8 scale
#48
I mean only in the manner of driving and setup (leaving the competition out)...
Regards
#49
the cars have more mechanical grip than a 1/10th , if you make the clutch a bit boggy, for club racing, it is actually easier to drive i feel. one stage 8th scale racing didnt do much for me , but once it went to the next level, i couldnt get enough of it, and still cant.
#51
When you are in the ballpark in terms of setup the car basically drives itself.
Since I'm pretty good in setting up a car and already steer a car on throttle input I think an 1/8 scale will suit me pretty well.
None the less, when going through a sweeper at full throttle for the first time will be quite a sensation.
#53
I usually run 200mm sedan and my son is racing 1:8th scale.
When I run my son's car every once in a while, it seems a lot easier to drive the the sedan.
The downforce and the huge amount of grip from the tires are way easier to handle than the squirrely sedan with a lot of power, skinny tires and a fraction of the downforce.
The 8th scale is much more forgiving, especially in those full speed sweepers.
To compete on the highest level with an 8th scale is a different story though.
Another thing that always strike me is, that when I'm in the pits for my son, I can't believe how much power those cars have.
Whern I drive it myself, I always catch myself thinking, that the car could use a bit more....
We will see.
Like Pattojnr said it has more mechanical grip and a huge amount of downforce.
#54
In the Netherlands it are mostly farmers that drive 1/8...also think it is easy
#55
Suspended
Roy Bakker on the other side likes to offend other drivers, but yeah ... he has no knowledge at all about 1/8 scale
#56
#57
I ran 1/8 scale for 4 years at national level and now i´m running 1/10 scale.
I can tell you that 1/8 scale isn´t easy. Unless you are just turning around. And that´s what makes it dificult.
To be fast in 1/8 you have to go beyond the limit that your head tells that is possible.
And then again. I´m talking about beeing fast. Not driving around. Thats easy with 1/10, 1/8, 1/5...
#58
Suspended
This is a good quote by the way:
If I have time I will have a look at the rooky class when you need to drive
