Old 02-09-2012, 03:43 PM   #541
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by DS Motorsport View Post
Now the question is who is a better optimizer?.
No one! Just get the Mugen clutch at ~ € 57 without pinions.
Unbeatable deal
stefan is offline   Reply With Quote
Old 02-09-2012, 03:52 PM   #542
DS Motorsport's Avatar
Unbeatable deal
Nahh, I prefer the red version. Plus it has some extra holes in the pressure plate which will make it lighter.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-10-2012, 12:36 AM   #543
Roelof's Avatar
Send a message via ICQ to Roelof
With my home made clutch I have thought of it but on the other hand just saving some tenths of a gram and at the same time loosing some support for the clutch shoe is not worth it.
But the best deal is this one:
http://www.redrc.net/2011/12/a-plus-...al-clutch-set/
I have seen these for just 35 dollar.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-12-2012, 03:55 PM   #544
Default Little tip for C801
If you're using the wheel nuts instead of the quick releases I got a little tip.
Don't know if others already had the same idea but I thought it was a pretty neat idea.
I really like the look of the wheel nuts and they do a better job of mounting the wheel absolutely true to the axle (less wobble).
However I was a little frustrated with the pins always falling out of the axle when you remove the wheel.
To keep this from happening you can use a small piece of 1/8 shrink wrap to keep the pin in place when you remove the wheel.
P1-RC.com
Old 02-18-2012, 11:01 PM   #545
dougday's Avatar
I use fuel tubing. Works perfectly
dougday is offline   Reply With Quote
Old 02-20-2012, 04:16 AM   #546
Default Gear shoes problem
Hi
I have a big problem with my c801
My gearbox don' work correctly
The screws 17006 try to destroy 2059
i thing this gearbox is too small....??
in my c01/02 the gear box work fine all time..wihout small screws
help me and sorry for my english...
G
georges972 is offline   Reply With Quote
Old 02-20-2012, 08:14 AM   #547
xtremes's Avatar
Originally Posted by georges972 View Post
Hi
G
Is the problem coming from the screws that hold the spur gear assembly or from the set screws which adjust the shoes distance from the drum (bell) ?
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 02-20-2012, 08:53 AM   #548
hi
i turn to make un small gap but think that this screws unscrew after
G
Old 02-20-2012, 09:00 AM   #549
hi
G
Please check the following message, it's advised to use some ca glue to lock the screws in place.
Hereby a small update on the C801 manual:
It is advised to use the small grub screw in the shoes for longer life of the shoes. We recommend to use some glue (ca) to secure the setscrew into the 2-speed shoe.
P1-RC.com
Old 02-20-2012, 09:07 AM   #550
dj apolaro's Avatar
This only works if you do it from the start. Not sure if they are available yet, but we have tested some different shoes here in the US and they work great. I am sure they will be available, just check with your dealers.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 02-20-2012, 09:38 AM   #551
ok thanks
But what glue
DJ other model shoes ?...please MP
G
Old 02-20-2012, 09:45 AM   #552
dj apolaro's Avatar
Any thin CA glue/Super glue will work.
I think the new shoe is a little harder material and a smaller hole for the set screw to make it tighter to put in.
Always use the set screw, even for sedan. I do just to make the shoes last longer. I can usually go a full season on just 1 set of shoes if you use the set screws.
DJ Apolaro
Old 02-20-2012, 09:47 AM   #553
Super glue or 'colle cyano' 'colle instantanée'
P1-RC.com
Old 02-20-2012, 09:51 AM   #554
Ok thanks DJ
my c02 work fine without this screws.. because no holes ..since 2yrs..zero problems never damage.
but my c801 gearbox.....
I use yr 801 setup fine...
congrats for yr winternats..
G
Old 02-20-2012, 09:54 AM   #555
instantanée....before screwing...????
if only when you screw first.....
