Old 09-10-2011, 04:41 PM   #451
DS Motorsport's Avatar
Originally Posted by speed6 View Post
What spring pre load do you use and clearance, also i noticed you use the yellow pad. What is the difference ?
Also i saw you are using white spring up front, what springs are those softer??
Can some one give me measurment of this spring and part number please.
Thanks guys
The white springs are the softest.
Capricorn Spring table:
www.dsmotorsport.nl/Manuals/Springs%20table.pdf
Capricorn Clutch setup sheet:
www.dsmotorsport.nl/Manuals/blank%20set%20up%20sheet.pdf
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 09-10-2011, 06:40 PM   #452
xtremes's Avatar
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 09-11-2011, 12:32 PM   #453
dj apolaro's Avatar
Thanks guys
Those front springs are actually Mugens. I am not using any yellow pad. Not sure what you are referring to. I use the stock brakes, actually those pads are still the originals and the black pad for the clutch. I use the yellow clutch shoe with the standard clutch.
Also Xtreme is correct about the front knuckles. Those are pre-production and I have not changed them yet.
Also, we just had the first Florida State Race this weekend and I could only go yesterday. Today was an additional qual and mains, so I am not running today. But yesterday I set the over night TQ. It was close between Paolo and I, but Capricorn took the TQ. Wish I could race today, would have made for a fun race.
Thanks,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 09-11-2011, 12:51 PM   #454
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Looking for great power at a great price http://kamikazercracing.com/proddeta...d=NOVA35plus21
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-11-2011, 01:20 PM   #455
Thanks,
DJ Apolaro
Hey DJ nice ride!!!!!
Thanks for your support much appreciate and also to the others obviosly
How come you are running Mugen upfront - are they softer as i have no steering off-power and thought of running softer fronts.
Also what about the new chassis whats the difference and how come you are not using the flex system?
speed6 is offline   Reply With Quote
Old 09-11-2011, 01:21 PM   #456
thanks
Old 09-11-2011, 08:01 PM   #457
dj apolaro's Avatar
The white mugen's are a little harder actually. They are between the stock and the yellow hards. Maybe add more rear droop travel to transfer more weight to the front to help with turn in. You can also make the rear camber link shorter to help this. Or make the rear camber link a little flatter. The less angle will help with turn in. A softer front sway bar in the front should help also with turn in.
DJ Apolaro
Old 09-13-2011, 04:13 PM   #458
Paulie Bee's Avatar
Default Two 1/8 Lab C801 For Sale Plus Extras $1000
sold
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 09-16-2011, 11:51 PM   #459
Default Clutch Spring & Wheel base question
Can you kindly confirm that the clutch spring part number you guys recommend is as follows cap417sh.
it also seems that everyone runs a short wheel base and when I checked the car the only way to make it shorter is by adjusting the front lower arm spacers. So how do you run the car in order to make it shorter?
And how do you set your caster than?
Old 09-20-2011, 03:16 PM   #460
BUMB
Old 09-20-2011, 04:06 PM   #461
When you want to shorten the wheelbase you move the 2,0mm black clip on the lower wishbone from the back of the wishbone to the front of it.
The same thing you do for the upper wishbone, move the 2,0mm black caster clip to the front of the upper wishbone.
Because you move both the upper and lower wishbone the caster setting won't be affected.
P1-RC.com
Old 09-23-2011, 05:26 PM   #462
Since I'm going to race my C801 for the first time this weekend I decided to check how much it weighs:
It's 100 grams underweight, this is not even funny any more.
This is completely stock with steel screws, standard servo's and even both front ARB systems, and a new set of tires.
Now I need to find a way to get all that weight into the car.
P1-RC.com
Old 09-26-2011, 04:38 AM   #463
Phil Trotta's Avatar
Default Lab c801 for sale
For sale
1 Complete roller ready to race
2 complete spare kit ( can build another car)
3 400-500 in spare parts
4 1 blitz r11 cut and painted
5 2 909 bodies cut and painted
Whole lot .... $900.00.
Pm me if interested for pics. I'd rather text pics to cell phone paypal or cash in person only. Phil
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 09-26-2011, 09:59 AM   #464
Phil what's up? What are you gonna run next season?
Old 09-26-2011, 02:03 PM   #465
Can someone suggest part number for front softer springs and is it best to go with Capricorn springs. Also kindly forward part number for clutch spring that you guys are using with the yellow shoe. Thanks
