Old 09-09-2011, 07:59 AM   #436
bullygod's Avatar
Originally Posted by JACK HAMMER View Post
Get yourself the yello clutch shoe also
Any idea what clutch spring part number is that? Are you using the HG shoes or normal ones? Thanks.
bullygod is offline   Reply With Quote
Old 09-09-2011, 08:06 AM   #437
xtremes's Avatar
HG ?
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 09-09-2011, 08:23 AM   #438
bullygod's Avatar
Originally Posted by xtremes View Post
HG ?
I am referring to the High Grip Brown/ Black or normal brown black shoes.
Old 09-09-2011, 08:39 AM   #439
xtremes's Avatar
The black clutch shoes is mostly used with the Aluminum clutch bell. If you're using the stock clutch bell, you should use the yellow clutch shoes with the black spring.
Vidal
___________________
Old 09-09-2011, 01:38 PM   #440
The earlier kits came with a super heavy spring the fits very snug in the cup in the clutch shoe. I ran this spring and had dusting until I installed 3/3 set screws in the flyweights then dusting stopped. The tension of the spring was flush with the clutch nut to start with a .6 gap
Capricorn now has a shorter spring less heavy that makes the car super smooth I run this spring with a .6-.7 gap starting at 1mm preload on the clutchnut ... Still with the screws in the flyweights
the stock gearing is funky. You may want to put a 19 pinion with stock spurs
as the 20 gives too numerically low of a gearing compaired to kyosho / mugen
Second gear ratios depend on track also.
As for set up dj set up is in this thread after page 13 somewhere.
When you quoted "Capricorn now has a shorter spring less heavy that makes the car super smooth I run this spring with a .6-.7 gap starting at 1mm preload on the clutchnut ... Still with the screws in the flyweights "
this setting is with the new spring? or with what i have?
What about the yellow shoe whats the difference?
speed6 is offline   Reply With Quote
Old 09-09-2011, 04:37 PM   #441
dj apolaro's Avatar
Hey guys,
Some of the racers asked me to post some photo's of my car. I am going to start getting ready for the nationals later this month. If you have any questions just ask.
Thanks to John Doucakis for the help on posting the photo's
Thanks,
DJ Apolaro
[IMG]http://data7.blog.de/media/074/5854074_fb40d9144c_l.jpg[/IMG
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 09-09-2011, 08:19 PM   #442
LOVE THE PICS DJ!
yappy is offline   Reply With Quote
Old 09-09-2011, 09:30 PM   #443
xtremes's Avatar
NICEEEEEE........JEJEJEJE
Vidal
___________________
Old 09-10-2011, 03:19 AM   #444
Phil Trotta's Avatar
This is with the black spring This spring fits in the clutch shoe retaining cup very easy. The harder spring is tight in the cup and a little taller on the clutchnut also it's like a silver/ gray
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 09-10-2011, 04:49 AM   #445
dj apolaro's Avatar
I also use the black spring. Have a much great sweet spot for the clutch. Trust me this will fix the dusting issue.
DJ
Old 09-10-2011, 08:38 AM   #446
musti72's Avatar
Hi DJ,
I looked at the pictures and couldnt figure out why you mounted one of the steering links to the upright from top, and the other one from bottom.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 09-10-2011, 10:35 AM   #447
xtremes's Avatar
Originally Posted by musti72 View Post
Hi DJ,
I think the early kits and pre production kits use the same front upright in both side then later on they made them symmetrical, which allow one to mount the steering linkage in the same position on both sides.....When I first got my car kit I had the same problem....
Vidal
___________________
Old 09-10-2011, 11:08 AM   #448
bullygod's Avatar
DJ
Hello DJ, thanks for sharing with us photos of your car. What improvements do you get from using the WC Chassis?
Old 09-10-2011, 02:14 PM   #449
SMcpot's Avatar
Trader Rating: 22 (100%+)
Thumbs up
Sweet-looking Cap, DJ.
SMcpot is offline   Reply With Quote
Old 09-10-2011, 04:17 PM   #450
DJ
What spring pre load do you use and clearance, also i noticed you use the yellow pad. What is the difference ?
Also i saw you are using white spring up front, what springs are those softer??
Can some one give me measurment of this spring and part number please.
Thanks guys
