Old 08-16-2011, 08:17 AM   #406
xtremes's Avatar
DJ, WHICH SPRING AND CLUTCH SHOE ARE YOU USING ? ALSO, ARE YOU USING THE SET SCREWS ON THE FLY WEIGHTS ?
THX
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 08-16-2011, 08:35 AM   #407
dj apolaro's Avatar
THX
I used the black spring from the kits and the black shoe recommended with the aluminum bell. I use my flyweights with no set screw and drill the non pin hole out with 4mm drill bit.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 08-16-2011, 09:10 AM   #408
xtremes's Avatar
DJ Apolaro
i SUPPOSE THAT IS THE SOFT SPRING, NOT THE HARD SPRING THAT CAME WITH MY KITS, RIGHT ?
Vidal
___________________
Old 08-16-2011, 09:35 AM   #409
dj apolaro's Avatar
Based on the spring I noticed in Paulie B's clutch. He had the same black spring I am using and he just got his kits. I think they are putting the spring I am using in the kits now. If you have the same spring as Paulie than we are all using the same spring.
DJ Apolaro
Old 08-16-2011, 10:49 AM   #410
I did not get a black spring in my kit, it's silver.
hmm
yappy is offline   Reply With Quote
Old 08-17-2011, 05:34 AM   #411
dj apolaro's Avatar
I think the silver spring is the super hard spring. Measure it in length and thickness. It needs to be between 9.5 and 9.8 in length and 1.7 to 1.9 in thickness. I do know that my spring in not silver and at the Worlds I could not get the silver to work. After the Worlds and some testing I found out it was the spring that was the entire problem I was having with the clutch dusting.
DJ Apolaro
Old 08-17-2011, 08:35 AM   #412
DJ Apolaro
wow
sounds good, im going to try the black one. because I am still having some dusting problems with mine and i'm using the silver spring.
I also noticed the silver spring does not spin freely in the cup or the nut.
Old 08-17-2011, 10:24 AM   #413
dj apolaro's Avatar
Hey guys,
Good results for the Capricorn this past weekend at the Xray Challenge
My 1/8 scale was great all weekend
http://www.redrc.net/2011/08/dj-apol...ge/#more-46433
Old 08-17-2011, 10:35 AM   #414
Hey guys,
Congratz !
Old 08-17-2011, 11:18 AM   #415
xtremes's Avatar
DJ Apolaro
That's very important information, DJ. Hopefully, it will help me get my clutch right for the GLC....1000 thx !
Vidal
___________________
Old 08-17-2011, 12:30 PM   #416
dj apolaro's Avatar
Vidal,
I will be there at the GLC also. See me if you need any help.
DJ Apolaro
Old 08-17-2011, 01:55 PM   #417
xtremes's Avatar
Vidal,
DJ Apolaro
OK...THANKS A LOT !
Vidal
___________________
Old 08-17-2011, 06:33 PM   #418
Hey DJ
you can now enter a second class for GLC are you bringing your 1/8 car?
I got some white 2speed shoes in direct from Italy but either I ordered the wrong ones or they shipped wrong either way they are too small must be 1/10 if you want you can have them.
Shepherd, Nova Rossi, KO Propo, DeSoto Racing
series - MWS and FORGASS
bmclean is offline   Reply With Quote
Old 08-17-2011, 07:03 PM   #419
dj apolaro's Avatar
Originally Posted by bmclean View Post
Hey DJ
Just running sedan. 2 classes is too hard. I am coming with Kenny and he is running 1/8 scale and I am running sedan. I am not even bringing my 1/8 scale.
DJ
Old 08-18-2011, 05:58 AM   #420
DJ
Whimp LOL I am running 2 classes but they are both 1/8 - see you Friday morning, busy at work or I'd be there Thursday.
