Old 08-01-2011, 05:52 AM   #376
Default 2 Speed setting
Dear all i am building by 801 and just came across the 2 speed. Do you have to tighten the screws where you hold the two sping all the way till the spacers and just leave them like that ???
speed6 is offline   Reply With Quote
Old 08-01-2011, 07:45 AM   #377
Phil Trotta's Avatar
You gently tighten both springs till they stop then turn them out 2.5 turns each. That's good starting point. Then adjust to your track. Two speed is ultra smooth
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 08-03-2011, 01:31 PM   #378
DS Motorsport's Avatar
Default Build report on LAB-C801
I completed my build of the LAB-C801 and will soon post a report of that here.
It will need some time to go through all the pictures and type up a nice report.
In the meantime a little tease of the exterior:
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-03-2011, 02:17 PM   #379
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Nice Daan
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-03-2011, 05:00 PM   #380
xtremes's Avatar
VERY NICE ! ALMOST AS NICE AS MINE......JEJEJEJE
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 08-04-2011, 06:23 AM   #381
Originally Posted by xtremes View Post
thank you....I'm very happy with the car.....was running it up in Connecticut this weekend.....the only problem I was having with it is the clutch.....Couldn't get it to work 100% right....Also the graphite pieces in the rear shocks kept on breaking by just gracing the board...Jary said he's been making some of those out thicker material....Hopefully I'll get some from him before the weekend.......
If you are talking about the carbon fiber piece on the lower rear arm, they also make them in "steel" If you run Contact tires I beleive the rims are smaller and can cause the Carbon Fiber piece to break easier.
Shepherd, Nova Rossi, KO Propo, DeSoto Racing
series - MWS and FORGASS
bmclean is offline   Reply With Quote
Old 08-04-2011, 11:48 AM   #382
xtremes's Avatar
Thanks for the info....
Vidal
___________________
Old 08-04-2011, 09:59 PM   #383
Jay7's Avatar
Send a message via AIM to Jay7
Exclamation
Anyone using the front wire sway bar on their C801? I can not screw in the ball cups on the bottom of the front arms. I applied serious amounts of pressure with the 4mm hudy driver and It will just not make a thread in the plastic. Any hints on how to put them into the lower front arms properly?
Jay7 is offline   Reply With Quote
Old 08-05-2011, 12:03 AM   #384
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
I heat up the ball cups with heat gun put it in the plastic while it hot and start making a thread, i dont know if thats the proper way but it works...
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 08-05-2011, 12:08 AM   #385
nitrodude's Avatar
Just get a tap and tap the plastic, when you screw in the ballcup it will go right in, and by taping it you also prevent the plastic from splitting.
When you screw the ballcup in without tapping it, all you're doing is displacing the material, when you tap it you actually cut material off.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-05-2011, 06:28 AM   #386
xtremes's Avatar
what should the size of the tapper be ? I'm getting my sway bar today ....
Vidal
___________________
Old 08-05-2011, 08:44 AM   #387
yes just buy the steel ones and you are good to go, i had the same problem. bought the steel ones and problem fixed.
yappy is offline   Reply With Quote
Old 08-05-2011, 06:15 PM   #388
nitrodude's Avatar
If the screw that threads ine th hole is 3mm, then get a 3mm tap. Make sure to get the high speed steel ones, dont get a carbon steel one, they are crap. Also, get a tap handle.
Steven Muller
Ronin Speed Parts
Old 08-05-2011, 11:54 PM   #389
xtremes's Avatar
I got it already....The size of the tap should be 8mm -1.
Vidal
___________________
Old 08-07-2011, 04:49 PM   #390
Default Steering Servo to Servo Saver Turnbuckle issues
Hey people, i am having problems installing the turnbuckle between the steering servo and servo saver as it seems that its really tight. What servo horn measurment do you suggest as i beleive that mine is way to long. Also the plastic turnbuckle end parts seem to bind with the servo saver and servo horn resulting in not a smooth turn. Tried shaving a bit the plastic and it did get better but still not happy with result.
