Old 07-28-2004, 11:00 PM   #31
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Post
i just hope that the mtx-4 will be released next year because i'm not yet done assembling my prospec and i still have to test it
buboy28 is offline   Reply With Quote
Old 08-03-2004, 02:26 PM   #32
Send a message via ICQ to Cartman
its going to come!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 08-03-2004, 04:41 PM   #33
afm
afm's Avatar
If the MTX4 is coming, and as done in the past, in which the MTX3 was a reduced copy of the MRX3, then what we might expect with the new MTX4 are the features of the MRX4
MUGEN MRX4
Low Center of Gravity:
New designed fuel tank for more low center of gravity ( mtx3 has it).
Throttle servo mount which lowers it up till the limit of chassis ( mtx3 has it).
Front Suspension:
New Front lower arm (1.5mm longer).
Adjustable height of front upper arm mount for roll center variation.
New designed front upright (King pin angle "0" degree).
Adjustable wheel base (3mm) in order to move front upper/lower arm forward and backward.
Rear Suspension:
New Rear Lower Arm (7mm longer).
Adjustable height of rear lower arm for the chassis side attachment in three stage ( mtx3 has it).
New designed rear upright (mtx3 prospec has it).
Drive system & brake:
Front universal joint excellent in drive efficiency is equipped as standard ( mtx3 prospec has it both ends).
Light weight 2 speed gear box and spur gear will be attached with one screw (not a performance upgrade).
Teflon brake pad, and Ventilated brake disk is as standard ( mtx3 prospec has it).
Light-weight centrifugal shoe, Super hard clutch spring, and Gray Clutch shoe are standard (mtx3 prospec has it).
Others:
Servo Saver, in which Ackerman can be adjusted by removing two screws (changing pieces the mtx3 has it).
New designed damper case excellent in maintenance (not a performance upgrade).
New designed engine mount which considers the twist of chassis equally right and left.
New floating centering system of rear body mount which brings more stability (not used with touring bodies).
New designed pivot ball excellent in maintenance (not a performance upgrade).
The car has more stability during the corner with new designed suspension compared with MRX-3.
Also, some optional parts for MRX-3 are now as standard parts for MRX-4.
So there we have an overview of some of the changes we might see on the MTX4.
Are they worth waiting, and not get a Prospec right now????
I haven't, I got my Prospec and I must say it is an awesome car, and when the time comes.....will see if the MTX4 is that much better.
AFM
afm is offline   Reply With Quote
Old 08-03-2004, 08:18 PM   #34
MUGEN MRX4
Front Suspension:
Rear Suspension:
Others:
AFM
I hope MTX4's front 1 way can be locked like the Surpent's front 1 way. I can see Surpent drivers have their advantage of changing the Surpent front 1 way to spool. I also like to see MTX4 came with overdrive driving system as stock kits.
challenger is offline   Reply With Quote
Old 08-03-2004, 09:29 PM   #35
kidDynomite's Avatar
Default Spool
Challenger, I too wish Kyosho made a spool for my RR Evo. I use similar settings to my sponsored Serpent friends at our track. Eversince I locked my oneway, braking and turning (on throttle) has never been more fun. And it's so easy to keep your line coming in on a hairpin turn after a long straight. Brake late, turn hard ... that'll stuff the one-ways costing in and the diffs who run a little wide. If you have an extra one-way, give this a shot ... here's how I did it ...
kidDynomite is offline   Reply With Quote
Old 08-03-2004, 10:38 PM   #36
Data's Avatar
Originally posted by Cartman
its going to come!!
the acrobat will be ready !
Data is offline   Reply With Quote
Old 08-03-2004, 10:55 PM   #37
Default Re: Spool
Thanks for the tips. I surely will give it a try modifying d mugen's 1 way. At the moment, I'm using KAWAHARA option spool for mugen, but its troublesome to change when need to test drive with 1 way in a new track.
Old 08-04-2004, 03:27 AM   #38
what about ball diffs??
Old 08-04-2004, 03:43 AM   #39
Sow&Steady's Avatar
Mark, there's ball diffs for the MTX? Front or rear or both?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-04-2004, 05:02 AM   #40
read all the thread. we are talking MTX4 and i am saying will ball diffs be on it?
There was a ball diff from mugen for the mtx2, but it never got released to the public
Old 08-04-2004, 05:40 AM   #41
compaq888's Avatar
Send a message via AIM to compaq888
Default Re: Spool
kid, these directions are much better and more clear, so basically this spool thing makes sure the one way has better response?
I see that you are very talented in making mods for cars that don't exist, why don't you go in business doing this, you can make a good profit
compaq888 is offline   Reply With Quote
Old 08-04-2004, 05:45 AM   #42
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Default GP4
still got it testing at moment. using mugen until i have hobao up to speed then pick best car!!
I already test my GP4 wow the car really good
suntok2 is offline   Reply With Quote
Old 08-04-2004, 06:27 AM   #43
Default Re: GP4
how many grams does it weigh?
Old 08-04-2004, 06:29 AM   #44
compaq888's Avatar
Default Re: GP4
the car looks like it has never been driven, also change your airfilter for a better air flow one.
Old 08-04-2004, 07:21 AM   #45
Default MTX4 Ball Diffs?
Cartman! I doubt there will be ball diffs on the new Mugen. I think they (Mugen) are all about competitive cars that are reliable and bulletproof. And from all the sponsored Serpent guys at our track, most wish they had a regular gear diff. Especially for the long mains. It's a lot of maintanance on a ball diff to keep it's settings consistent. But they are lighter and smoother in rotation.
mugen mtx4 easy1 R/C Items: For Sale/Trade 2 08-08-2008 07:42 PM
Mugen MTX4 bluejays R/C Items: For Sale/Trade 3 06-23-2008 11:28 PM
mugen mtx4,mtx4-r rcfreak541 R/C Photography 0 06-29-2007 11:03 AM
Mugen MTX4 SherKahn Australia For Sale/Trade 4 03-04-2007 03:46 AM
looking for a mugen mtx4 rc.racer R/C Items: Wanted to Buy 0 08-13-2006 05:31 PM
