Old 05-31-2011, 04:20 PM   #106
Pro Models's Avatar
Tks for the info wingracer.
Originally Posted by wingracer View Post
OS2 IS the Kyosho/Mugen offset. The only difference is the little bevel on the backside. You can use them like they are, or you can get beveled spacers to put on the car if you wish.
Pro Models is offline   Reply With Quote
Old 06-02-2011, 03:15 AM   #107
Send a message via MSN to PMSorber
Originally Posted by Pro Models View Post
Hi guys any setup news from the Euros, I saw a V8 was on pole.
Quick question can the Serpent OS2 rims be used on the V8 or is it only kyosho/mugen ones that can be used?
Here you go:
Width: 253 / 264
Hight: 8 / 9 on 74 / 67,5 wheels
Toe front: 1,5 (3 total)
Toe rear: 2,5 (5 total) depending a bit on rear stability
Camber front: 1 / 1,5
Camber rear: 2 / 2,5
Caster front: 3mm (total)
Front rollbar: soft
Rear rollbar: standard
Downstops: 1 / 7
Excenter front: short (to rear)
Excenter rear: none, big bearings
Upright spacer front under steering linkage: 2mm
Upright spacer rear: 3mm
Akkerman: pulled fully to the front
Rear lower A-arms: mid position
Damper-front: 650 1 hole 70% rebounce
Damper spring front: Serpent green (new), blue or red standard will work as well.
Damper-rear: 800 3 hole 20% rebounce
Damper spring rear: Serpent blue front spring (new), Blue will work as well.
Body: P909
Body position: 24mm
Gurney: 10 - 13 mm (depending upon rear stability)
To gain more corner entry steering you can raise the rear end of you upper front A-arms. Spring load is important, setup the ridehight correct for the correct load.
Goodluck!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 06-03-2011, 02:01 PM   #108
avs
avs's Avatar
Originally Posted by PMSorber View Post
Here you go:
Width: 253 / 264
Front rollbar: soft
Downstops: 1 / 7
Body: P909
Body position: 24mm
Goodluck!
thanks for the suggestions, but can i ask you to explain some things?
for ackerman, are you using the rear servosaver post position?
what shock positions are you using? are they the usual middle in front and lowest/inner on the rear?
i am not familiar with serpent springs, but they are listed as having the same spring rate front or rear for a given color. so what is the purpose in using the front spring on the rear? is it to be more progressive or ?
Tony Shimko
avs is offline   Reply With Quote
Old 06-03-2011, 04:00 PM   #109
ugglasdav's Avatar
quick question. do u have to set ur droop before u set ur chamber. or can us set up ur chamber and then do the droop afterwords. thanks. also can anyone give me some setup tips based around the standard setup for a very low traction track.
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 06-04-2011, 08:27 PM   #110
wingracer's Avatar
Trader Rating: 24 (100%+)
White or dark green springs, softer oil, more overdrive, if you need more steering, raise the rear lower arms.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-05-2011, 02:47 PM   #111
1 - Ackerman, yes rear position
2 - mid front, one up from lowest rear
3 - higher initial action force (need more initial power to get a spring rate)
The sequence is:
1 - set up riding hight on a correct set of tires.
2 - set up droop (downstops) without and with rear roll-bar
3 - set up rear toe
4 - set up rear camber
I would not do that. It takes bite / grip away rear, resulting in more steering. I would sooner opt for roll-center change at the front (besite springs, oil etc). So change the front.
@ConSult Trading
Old 06-06-2011, 02:40 PM   #112
Default Velox
Does anyone know for sure what plastic the new car kits come with? The original softer plastic, or the hard or even extra hard plastic?
Thx
dyoung is offline   Reply With Quote
Old 06-06-2011, 04:54 PM   #113
ugglasdav's Avatar
another quick question, can i use 13mm droop guage blocks for a 1/8 car?. thanks
>>>Sanwa m11x
Old 06-06-2011, 11:50 PM   #114
No.
Thx
In the kit there is normal plastic, I would not say softer plastic.
@ConSult Trading
Old 06-07-2011, 05:31 AM   #115
ugglasdav's Avatar
No.
what size blocks would i need
>>>Sanwa m11x
Old 06-07-2011, 07:40 AM   #116
avs
avs's Avatar
i would think it depends on the gauge you have to measure. you just want to be able to measure between 10mm above to 2mm below the lower surface of the chassis plate.
Tony Shimko
Old 06-07-2011, 07:46 AM   #117
You would need 20mm blocks.
http://www.teamcracing.net/index.php...mart&Itemid=71
@ConSult Trading
Old 06-07-2011, 09:07 PM   #118
GMartinez's Avatar
Trader Rating: 85 (100%+)
Default Now in stock
http://www.superiorhobbies.com/istar...d=SMR600011!SH
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-08-2011, 05:08 AM   #119
Pro Models's Avatar
hi guys are the majority of you using a softer shore tire up front to gain more steering or is the traditional same shore all around still being used?
Would a 35/32 be the right choice ?
Old 06-08-2011, 07:31 AM   #120
avs
avs's Avatar
for the past few years a step softer front has been common. last week i used 32/35 for qualifiers and 35/37 for the main.
things have changed a lot, 35/30 was the norm on my serpent vector.
Tony Shimko
