Old 02-04-2013, 11:29 PM   #226
ND
Originally Posted by b_esser View Post
ZEDRC....
I have looked everywhere for this and have not found it anywhere. What I have found is only an 8mm shaft conversion with lightweight 2 speed produced by Andrea Pirani. If you know where I can find the pulley conversion I would like to see one also.
Pirani pulley upgrade
http://www.fvssshop.it/prodotto-1444...PIRANI-RC.aspx
ND is offline   Reply With Quote
Old 02-08-2013, 04:12 AM   #227
Patrick will publish all news very soon!
Last test´s next week at the Winternats.
A-Man
veloxrc is offline   Reply With Quote
Old 02-17-2013, 06:09 PM   #228
Default 1:8th Shepherd V8 eleven
There is a beautiful complete 1:8th Shepherd V8 eleven for sale shown on Ebay. Full roller chassis, engine, exhaust system, fuel cooler, servos, 3 new bodies, transponder, and more.
http://www.ebay.com/itm/261169852696...84.m1586.l2649
TM America is offline   Reply With Quote
Old 02-26-2013, 04:33 AM   #229
Hi,
any suggestions or better pics how you are increase the rear body height.
When using the aluminium body mount extensions the body gets very weak in the middle which is certainly not helpful for rear axle grip.
thanks,
tom
mugentom702 is offline   Reply With Quote
Old 02-26-2013, 04:55 AM   #230
wingracer's Avatar
Trader Rating: 24 (100%+)
I had no problems with the extenders though I now use longer Mugen uprights to raise the whole mount instead.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-26-2013, 05:58 AM   #231
The "short" or the long Mugen ones? I tried the long ones and I feared the centering pin has not enough space for the upwards travel due to travel limitation from the carbon?
Old 02-26-2013, 04:03 PM   #232
wingracer's Avatar
I also use the CEFX rear tower so that wasn't an issue for me. Not sure how high you can go with the stock tower.
Team Shepherd USA
Old 03-01-2013, 08:58 AM   #233
IgorR's Avatar
A-Man
Any news?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 03-31-2013, 03:37 PM   #234
Shepherd hosts season opener at beautiful WMC-Wiesbaden track,
Read the invitation below:
It's a pleasure to invite you to the "Shepherd Season Opening" at the nice racetrack in Wiesbaden at the 20./21. of April.
It will be a pleasant get-together with tech-talks, drinks, food and full factroy support for every attending Shepherd driver.
It would be nice to welcome you at this event to have a good start into the upcoming season at the track of the ProStockSeries Final (formlery known as Hobby Cup).
See you on the racetrack...
Your Shepherd Micro Racing Team
You can find the event on FB
Greetings
Thilo Alexander
# Team Shepherd # http://rccar24.com/ # Brilliant RC # PICCO # Matrix Racing Tires # Hitec/Multiplex # looxon stickers
thilo-alexander is offline   Reply With Quote
Old 04-30-2013, 08:12 PM   #235
Condor Speed's Avatar
Cool
Are we getting a new 2013 Shepherd Velox V8 this year?
Top photon EX 13.5 Trinity D4, Lrp Flow Works R1 Lipo
Top Photon EX 25.5 USVTA Novak Fanton Lipo
Xray NT1 Picco
Desoto Racing
RC Target
Condor Speed is offline   Reply With Quote
Old 05-01-2013, 03:14 AM   #236
JamesHealey's Avatar
Yeah 2013 V8 will be coming soon!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 07-24-2013, 12:07 PM   #237
MjoyRacer's Avatar
All the new Velox Pro 2013 items are instock and available online @ www.team-shepherdusa.com
We are having some great specials on the new pro kits as well as sonic engine items. Check them out ....Under the "Summer Specials" on the website!!
SHEPHERD Micro Racing USA / Nugget's Racing, LLC / www.Team-ShepherdUSA.com / www.NuggetsRanchRaceway.com / Metal Works / Girl Racer!!!
Last, but always first #26's wife and Little Nugget's Mom!
MjoyRacer is offline   Reply With Quote
Old 08-29-2013, 05:52 PM   #238
SRAD's Avatar
Default Velox V8 Pro upgrade question
In upgrading my Velox V8 with the Pro front sway bar.....is there a default length measurement the sway bar links should be that connect the front arms to the sway bar? Thanks
SRAD is offline   Reply With Quote
Old 08-29-2013, 11:39 PM   #239
Trader Rating: 4 (83%+)
Build the links as longs as possible without them touching the upper arm when suspension travels (15mm to 20mm from bottom of arm to top of the link).
Shepherd Micro Racing @ Novarossi @ Matrix Tires @ VP Fuels @ Nugget Racing
Roniel_R is offline   Reply With Quote
Old 08-29-2013, 11:45 PM   #240
SRAD's Avatar
Thank you...also curious why the instructions have you cutting the rod ends a bit? Again thanks for the response.
