Old 05-11-2012, 06:49 PM   #196
X4
X4's Avatar
Originally Posted by Mind11 View Post
HY
I got a Hard Chassie for my Velox and have the Problem that the Screwholes are not sunk deep enought so the screws stands out 1 mm. Had anyone the same problem ?!?!
Thx
Yep, i have to keep changing those screws out after every one or 2 races becoz i'm afraid they'll strip.
X4 is offline   Reply With Quote
Old 05-17-2012, 12:20 PM   #197
2CARTEAM's Avatar
Originally Posted by kmh View Post
Been running the Shepherd for a little over a year now. Ran the R15 at the recent Kosmic Fuel race. Even though the 909 is a very good body, the R15 brought the car to life in the corners.Have not tried the R18 yet.
Thanks for the feed back. I'll have to check out an R15. How much gap did you use from the front bumper to the edge of the body?
Also this series of questions is for everyone out there. We are new to the car and would appreciate any input we can get.
Can you please explain what the following adjustment do to the car?
1. Raising or lowering the front upper roll center?
2. Using the eccentric in the front hubs in the three positions
a) upper
b) middle
c) lower
3. Using a shim in the front knuckle where the steering tie rods connect?
4. Moving the ackerman forward or backwards?
5. Increasing or decreasing the angle on the front sway bar.
I thank you in advance for any input we can get.
Ko Propo America, Ulti tires,Vp Racing Fuel, Rc Target, Capricorn, ASM engines, Activ rc, Lion art prints,
2CARTEAM is offline   Reply With Quote
Old 05-17-2012, 02:44 PM   #198
YBSLOW's Avatar
FRONT ROLL CENTER
Front roll center has most effect on on-throttle steering during mid-corner and corner exit.
FRONT ROLL CENTER EFFECT
Lower
• Increases on-throttle steering.
• Decreases car’s responsiveness.
• Decreases weight transfer at front of car, but increases grip.
• Increases chassis roll.
• Better on smooth, high-traction tracks with long fast corners.
Higher
• Decreases on-throttle steering.
• Increases car’s responsiveness.
• Increases weight transfer at front of car, but decreases grip.
• Decreases chassis roll.
• Use in high-grip conditions to avoid traction rolling.
• Better on tracks with quick direction changes (chicanes).
FRONT ANTI-ROLL BAR
The front anti-roll bar affects mainly off-power steering at corner entry.
Stiffer
• Decreases front grip (increases rear grip).
• Increases off-power steering at corner entry.
• Quicker steering response.
Softer
• Increases front grip (decreases rear grip).
• Decreases off-power steering at corner entry.
• Slower steering response.
Adjustments on the Front Hubs
Reduce the track width
More Steering > Move up the wheel shaft using the eccentric (pay attention
to the Down-Stop)
More Steering 1st half of curve > Move forward the wheel shaft using the
eccentric
More Steering 2nd half of curve > Move backward the wheel shaft using the
eccentric
The shim on the steering arm under the tie-rod changes the bump steer.
Ackerman adjustment, I notice the further forward you push the servo saver the more aggressive the car is in the middle of the corner and makes the car more twitchy.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 05-17-2012, 07:07 PM   #199
casino57's Avatar
Hi Sheperd guys....I'm selling tons of new and used Sheperd velox V8 parts. I have chassis's, set screws,springs,axles,clutch parts,1000's of dollars worth of stuff. If anyone is interested pm me and I'll get in touch with you to talk about price. I even have a new painted body that will go to the guy that needs this stuff the worse!!!
Mike Garcia - RCAmerica - XRay T3
Trinity - JDR - Hudy - KoPropo America
Laser Products - Tekin
Leisure Hours Raceway & Hobby Shop
casino57 is offline   Reply With Quote
Old 05-19-2012, 02:36 PM   #200
kmh
a) upper
b) middle
c) lower
11mm bumper to front of body
kmh is offline   Reply With Quote
Old 05-21-2012, 10:08 PM   #201
kmh
Default Bad part?
Hello everyone. I recently purchased the low friction front belt for my v8 and the belt is to short. I tried every adjustment short of drilling new holes to accommodate this belt. Has anyone else had this problem.( part #906107)
Old 05-22-2012, 01:45 PM   #202
There are two different size front belts, a 201 and 210 mm. If you have not updated the pulleys to the new version, you need the 201mm belt. If you have updated, you need the 210mm belt. sounds like maybe you have the new pulleys but got the 201mm belt.
dyoung is offline   Reply With Quote
Old 05-23-2012, 06:52 PM   #203
kmh
Thanks for the info. I have the new pulleys that came with the '11 kit. I thought that the low friction belt was a new option. I have not seen two different size "low friction belts" even though the regular belt (606117) says 210 mm. Thanks again.
Old 05-26-2012, 01:31 PM   #204
Default Opton parts new 2pcs upper deck and new front anti roll bar
Hi guys, have anyone try the new 2pc upper deck and front anti roll bar? If yes, what set up that we can achieve to get more steering?
shambmk is offline   Reply With Quote
Old 05-28-2012, 05:18 PM   #205
MHarrison's Avatar
I added the front wire bar this weekend. Gives the car just what I was looking for . Plenty of steering.
Helpful tips: make your links 30mm in total length.
if you desided to run your upper arm pins in the lowest setting, remove the bottom set screws. or the up travel will hit the wire bar.
MHarrison is offline   Reply With Quote
Old 05-30-2012, 07:12 PM   #206
2CARTEAM's Avatar
Thanks KMH.
Old 05-30-2012, 07:15 PM   #207
2CARTEAM's Avatar
Did it give you more initial , mid or exit steering. We ran the stock front sway bar this weekend and were looking for more initial. Also what body did you use?
Old 05-31-2012, 01:45 PM   #208
MHarrison's Avatar
It added more initial to my car. ( it really made the car twitchy and nervous ) but it was High traction this past weekend). .
I run the Blitz R15 ( dome ) body. Mounted dead center of the front wheel cut out scribe marks
Old 05-31-2012, 05:26 PM   #209
2CARTEAM's Avatar
Hi Mark
Jr likes a twitchy car so that might just be what the doctor ordered....BTW did you mean the Blitz R18? It looks like the 909. So you mounting it using the front axles dead center of the wheel wells? Thanks for the info.
Old 05-31-2012, 06:11 PM   #210
MHarrison's Avatar
Hi Mark
Yes ,, sorry, I just got back into racing .. I got confused ..... I did mean R18, And yes I Mounted it using the front axles dead center.
I was Shocked how much steering I was TAKING OUT .. And I love a nose heavy car. Even After it rained ,,The car still had very good balance with no changes .
