Old 10-07-2011, 10:15 PM   #166
quietstorm76's Avatar
Default Got my kit
Very well organized kit. Parts fit is really good as well, quality is right up there with other kits I've built. Goes together really fast too. Only had about an hour before the family got home and I was able to complete most of the rear end in that time. Looking forward to putting this machine on the track.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-08-2011, 03:38 AM   #167
Send a message via Yahoo to fabiosweet
So beautiful!
fabiosweet is offline   Reply With Quote
Old 10-17-2011, 09:35 AM   #168
I got to track test my V8'11 this weekend and had very good results. With medium traction, the box setup is very stable and balanced using a P909. The car responds to very small changes. I tried both fixed top deck and flex top deck options and there is a noticeable difference but not drastic. No mechanical issues, no broken parts. The setup posted I was using the Flex radio tray option.
Primary Weapon: ?
Secondary Weapon: ?
Old 10-26-2011, 11:09 AM   #169
I had another successful weekend with the car. By successful I mean no broken parts or mechanical failures and handling was the same as previous week.
Tried flex and fixed radio tray back to back and this is what I found:
Flex:
Increased grip all around but it felt lazy to me.
Very stable
Fast in sweeping turns
Fixed:
Less grip overall
More responsive, faster thru chicanes
More rotation in 180s
Primary Weapon: ?
Secondary Weapon: ?
Old 10-26-2011, 11:33 AM   #170
YBSLOW's Avatar
Flex:
Very stable
Fixed:
Less grip overall
I ran similar setup, I liked the flex radio tray but ran blue rear and white frt springs with R15 body. 909 always feals lazy to me. The brakes on this car are the best I have felt on any car yet. They do take a lap to get up to temperature but no fade at all.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is online now   Reply With Quote
Old 10-26-2011, 01:58 PM   #171
I haven't tried an R15 yet but I've heard it's more responsive. How far in front of the bumper do you mount the R15? I agree on the brakes too No fade and very consistent.
Primary Weapon: ?
Secondary Weapon: ?
Old 10-26-2011, 03:21 PM   #172
YBSLOW's Avatar
I will check it later...........pretty much centered up on the front wheel well marks. I also ran the adjustable rear sway bar full stiff.
YBSLOW Racing
Old 10-26-2011, 03:23 PM   #173
Ok thanks
Primary Weapon: ?
Secondary Weapon: ?
Old 10-26-2011, 11:45 PM   #174
Send a message via MSN to PMSorber
17 - 19mm to get a decent turn-in.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 10-27-2011, 04:25 AM   #175
Thanks for the info
Primary Weapon: ?
Secondary Weapon: ?
Old 01-15-2012, 05:14 AM   #176
X4
X4's Avatar
As support for Patrick
1 - By changing the excenters you will change quite a lot with the car. Setting them down will change the downstops and increase the time to run on a set of tires. Setting them backwards you will increase steering (on- and offpower). In general you just increase the downforce on your front tires by moving them more to the center of downforce of the car
2 - It will loosen a bit after some runs.
Hi all, firstly, i would like to say that the V8'11 is a fantastic car and i'm extremely happy with it.
In regards to the eccentrics, does the above apply to the rear?
X4 is offline   Reply With Quote
Old 03-17-2012, 03:57 AM   #177
IgorR's Avatar
Hello,
Does anyone konw if Shepherd is preparing a twelve edition or an update of the Eleven for the Velox V8?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 03-17-2012, 04:06 AM   #178
Originally Posted by IgorR View Post
Hello,
Give it about two weeks...
@ConSult Trading
Old 03-17-2012, 04:11 AM   #179
Hmmm... nobody answered this one .... We only use big bearings at the rear for 90% of all races. The same applies for the rear but can also be changed by using more simms on your uprights.
@ConSult Trading
Old 03-17-2012, 06:35 AM   #180
IgorR's Avatar
Interesting news...
Yokomo YR-X12
Shepherd Velox EC
