Old 07-19-2004, 11:12 AM   #1
Default RB V12: What % nitro?
I just bought a V12 along with some 30% Byrons which was recommended by my LHS. The manual from RB indicates a maximum of 20%, do I need to shim the head, run a different Turbo plug?
How much power is 30% really worth and does durability really suffer? The RB manual indicates accelerated aging with higher nitro.
a68cougar is offline   Reply With Quote
Old 07-19-2004, 12:43 PM   #2
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
On my humble opinion, unless you are runing on a open outlaw 200mm racing category and want the ultimate power, its not worth the 30% nitro fuel ...
You might use some good brand 16% nitro racing fuel ... not more ... thats all you need, the rest its on your hands on the TX and on the setup.
cya !
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-19-2004, 01:15 PM   #3
chicky03's Avatar
Send a message via AIM to chicky03
Since we are in the same region this might help. I ran my Rody V12 at toledo this weekend and ran a .1 and .3 shim, #6plug and 30% odonnell. It ran like a raped ape. Last week I only ran it with a .1 shim and it was better for sure with more shims. On RB's website it says the .12 are setup for 16% and to add .1 for every 5% you go up on the nitro. Or you can just stay with 16% but I have never tried it.
Paul
chicky03 is offline   Reply With Quote
Old 07-19-2004, 05:27 PM   #4
wild gopher's Avatar
Trader Rating: 39 (100%+)
i have an V12 as well and use 30% and whatever shims were on there (if any). Does anyone know the shim size that is from the factory?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 07-19-2004, 05:40 PM   #5
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Ok....here's the deal.....the part numbers for the shims are..p/n 1700-020...
I'm running the std v12......non turbo.....1 shim added...Sidewinder 30% world championship formula(which has ALOT to do with how well the engine runs and tunes)
this motor is WAY faster than my OS turbo even dreamed of being.......Second gear on my r40 comes on like an afterburner........
Go RB!!! GO Sidewinder!!
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-19-2004, 05:52 PM   #6
I would strongly recommend using 30%, if you know how to tune the eng, wear on the eng due to higher nitro content will not make much difference. Also, you can always find someone to resize the sleeve. There seems to be more benefits to 30% when compared to 20%.
vadn1 is offline   Reply With Quote
Old 07-19-2004, 05:54 PM   #7
mine is the turbo version, just removed the head and found one silver shim on it. Not sure of the size but my question is by adding another shim, will i increase power or take it away. I know that by having less shims the compression goes up, but where do i find my medium?
Old 07-19-2004, 06:45 PM   #8
Thanks for all the great advice!!! Since this is my first nitro, after 1 year of electrics, I think I'll run the remainder of this season with 20%. If I am little slow, I will make the switch to 30% next year, since it seems tuning becomes more critical with 30%.
A couple other questions:
1) Do you have to repeat the entire run-in procedure when switching to another %?
2) How can you determine if a shim is necessary, do you just try it?
Old 07-21-2004, 05:03 PM   #9
Actually it seems easier to tune with the higher percentage of nitro ....
Old 07-21-2004, 06:18 PM   #10
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
cya !
there is a big power difference between 16% and 30% i have a OSTR that i run 30% fuel and that motor has 2 1/2 gallons of fuel through it and still has alot of compression, and it runs around 245 degrees. It all depends how well you tune your motor just like fastharry stated a few post above^^
Old 07-21-2004, 06:20 PM   #11
Super Moderator
Marcos.J's Avatar
no you donot need to do run in procedure
to determine how many shims you have to check and see how your glow plug looks like after every run
Old 07-21-2004, 06:26 PM   #12
compaq888's Avatar
Send a message via AIM to compaq888
is my v12 a turbo??? because it came with a regular glow plug and on the box it says "1700-000410" and it says "RB V12 3T/SA/BN/SPT/TIR"
so how can it be a turbo if it doesn't use a turbo glow plug?
compaq888 is offline   Reply With Quote
Old 07-21-2004, 06:32 PM   #13
thats a standard, my turbo is 1700-000430
Old 07-21-2004, 06:43 PM   #14
compaq888's Avatar
fudge
i specifacally asked for a 3 port turbo, what am I suppose to do now? is it cheaper to exchange it and get a turbo version or how can i convert it to a turbo?
Old 07-21-2004, 09:03 PM   #15
Super Moderator
Marcos.J's Avatar
Originally posted by compaq888
fudge
change the button
LOOKING TO BUY RC NITRO TRUCKS, CARS, BUGGYS, ELECTRIC OR NITRO CASH IN HAND jd267 R/C Items: Wanted to Buy 26 09-06-2008 12:25 PM
WTTF: mini electric or nitro (nitro perfered) and also looking at all nitro deals.... xxx-ntad2 racer R/C Items: Wanted to Buy 3 04-25-2007 07:53 PM
XM Ready radio and Nitro Buggy to trade for Nitro Rustler or Jato RTR NewNitro R/C Items: For Sale/Trade 1 03-17-2007 11:38 PM
FS/FT Tmaxx, Nitro Rustler, Nitro RS4 Racer, Nitro RS4 RTR, Losi XXXNT RTR ChrisR40 R/C Items: For Sale/Trade 24 03-20-2006 03:47 PM
FOR SALE:Nitro 4tec, Hopped Nitro Rustler, Parts lot, Picco .12 engine, plus more!!!! feel my impact R/C Items: For Sale/Trade 0 08-05-2002 10:41 PM
