Old 09-09-2004, 10:48 PM   #256
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Mazda Body Location
Originally posted by InitialD
I think he did the opposite. From the talk back of his race report on mytsn, he had to dial out steering from the car to avoid traction roll.
http://www.mytsn.com/forums/forum.as...2568&pid=10619
You're right, as usual Master D I realised I'd posted a stupid question when it was too late ho hum!
markp27 is offline   Reply With Quote
Old 09-09-2004, 11:37 PM   #257
AMGRacer's Avatar
Originally posted by rjl
Does anyone know what shore tyres were used during the final?
Haras setup sheet shows 42 F/R.
AMGRacer is offline   Reply With Quote
Old 09-10-2004, 12:39 AM   #258
Suspended
Default new mega engine
does anyone have a close up shot of the new mega engine that was used by team serpent?
SERPENTFREAK69 is offline   Reply With Quote
Old 09-10-2004, 07:19 AM   #259
Vue Vang's Avatar
IS THERE A LINK TO ALL THE PICTURE? SORRY IF I DIDN'T SEE IT.
Vue Vang is offline   Reply With Quote
Old 09-10-2004, 09:12 AM   #260
Default Re: new mega engine
Brian Berry is offline   Reply With Quote
Old 09-10-2004, 09:15 AM   #261
Trader Rating: 16 (100%+)
Originally posted by mikemyers
There's a series of 23 photos posted showing the start of the race. My camera can shoot at 8fps, and this is the only time I tried that during the race - several small bursts to cover everything. In hindsight, I should have just left it running at 8fps for the entire start, but I was worried that it was using up memory space way too fast.... Anyway, but for one car that bobbled, these guys showed how it should be done, with a nice clean start.
Mike, as I mentioned over at the racer grid forum, your pictures are PROFESSIONAL level..........of course, that Nikon definitely does the magic, it is very rare to see some crystal clear RC racing pictures now a day espeically those pictures that shotted while they are in action............good job.
P.S....I am also very interested to see the rest of the A-main drivers pictures....like Lin's CD3 or Berry's S710's close up body removed pictures.....if possible, thanks.
Old 09-10-2004, 09:18 AM   #262
Default Re: Re: new mega engine
Originally posted by Brian Berry
Brain...........thanks for the pictures, do you have any informaiton about the release date of those engines? Also, ORANGE HEAD now? To match the ORANGE SCHEME of Serpent? That is a nice touch.......
Will you be at the Chicago Hobby Expo a month later...? Hope to see you there............
Old 09-10-2004, 09:24 AM   #263
If Mr. Barry Baker still around here....can you give us your GEARING information? I know you are running the Yokomo Centax...but are you running the 21/27 pinion or the 22/29 max pinion? Thanks.........
Old 09-10-2004, 10:06 AM   #264
Default Re: Re: Re: new mega engine
Not sure if I will be coming to the Chicago show. Still to far ahead....LOL
Serpent will release information on the MEGA line of engines on their website myTSN I'm sure sometime soon. I think someone mentioned later in October. I may be wrong but don't have a date yet. Check out www.myTSN.com for the latest on the MEGA engine line and its updates.
BYW...... They are very good engines.....
Old 09-10-2004, 10:48 AM   #265
markp27's Avatar
Hi Brian,
Question for you:
Just looking at the picture of the 710 there and noticed that you've it has the thicker rear anti-roll bar on it. Why was this used if the car was suffering with traction roll?
Cheers, Mark.
Old 09-10-2004, 11:10 AM   #266
It actually produces more rear bite = push. It also keeps the rear of the car from rolling and staying flat.
Old 09-10-2004, 02:46 PM   #267
markp27's Avatar
Thanks for the answer - I understand about the rolling bit and staying flat, but I always thought a roll bar would reduce grip at the end to which it is applied - have I misunderstood something?
Cheers, Mark.
Old 09-11-2004, 01:40 PM   #268
Motorman's Avatar
Team RD Logics setup for the 710.
we had on power push issues early in the week we tried to solve and adding as much as an ounce and a half to the front of the car helped.
we ran 2 setups
ours early in the week and on friday
and the serpent team setup on saturday.
Sunday we went back two our setup as we felt with the solid axle the car just did not rotate well. Brian ran well with that setup. I've watched Brian run a long time and I could tell that setup was holding him back.
what we ran. 4 of us worked on setup for a couple weeks.
front
camber +2
wheelbase shortened 3 MM top and bottom
caster 2mm clip in front
shock oil 80 or 100 wt
shocks 3 holes open
shocks layed down 3 holes
springs red
swaybar stood straight up
Front upper roll center at upper most adjustment
tires 42 shore 58 MM
I ran 1 0z additional weight under the front axle (Hudy Xray weights)
Rear
camber +4
toe 2.0 to 2.5
shocks 80 wt oil
3 holes open
shocks stood straight up
springs red
2.5 bar 10 MM in on pivots
roll up on lower arm
roll center middle inner on upper arm
drs arm up
42 shore tires 58 MM
pinion gearing 16-21
yellow or red shoe
stock flyweights
950 R spring
The car was good on thurs friday and saturday but a little tippy over 59 MM on tire dia on sunday. I just could not push the car hard.
The Team serpent setup seemed a little more forgiving for tippiness.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 09-11-2004, 02:20 PM   #269
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Motorman
Thanks for the pipe at the Nats.
Sorry you had a bad day on Sat. Paul Rush...................
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-11-2004, 02:35 PM   #270
FW-05RR's Avatar
Originally posted by Aaron_ETF
Is this his Display car, or the car he race. Look so clean
that looks like his display car look at the fuel tank..... Im sure that fuel tank hasn't seen a single drop of fuel
FW-05RR is offline   Reply With Quote
Racing in Toledo, Ohio? molesc4 Track Locator Forum 13 11-04-2013 12:38 PM
Toledo Ohio, summer racing airshot Micro and Mini Scales 0 06-05-2008 12:31 PM
Toledo Ohio summer racing airshot Racing Forum 0 06-05-2008 12:24 PM
Toledo OHIO RACERS, please look Fastburn Nitro On-Road 2 04-21-2003 04:22 PM
Nitro Sedan Nats - Cinci , Ohio Woody Nitro On-Road 16 04-29-2002 09:15 AM
