Old 07-18-2004, 08:16 PM   #1
Bandeira's Avatar
Send a message via ICQ to Bandeira
Default Drag Brake
Hey guys...
Havin' problems setting the drag brakes consisntently... they keep changing from run to run... Anybody got any good advice on this issue?
Thanks in advance...
cheers...
Bandeira is offline   Reply With Quote
Old 07-19-2004, 04:16 AM   #2
cyba888's Avatar
What servos are you using, you need to make sure your servos have enough torque in order to work consistent. I havent installed mine yet but im guessing that may be your problem.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-19-2004, 05:39 AM   #3
Bandeira's Avatar
I do use hitorque servos... nah... that's not the problem... I don't know numbers but they are FUT9404
Old 07-19-2004, 05:59 AM   #4
ziggy12345's Avatar
Default Re: Drag Brake
Originally posted by Bandeira
Hey guys...
cheers...
Set it up so the trim on the radio adjusts the drag brake. Set the drag brake before every race by running with none then adjust the trim to increase it until it feels right
Its impossible to set it up on the linkage and expected it to be the same every meeeting or even every heat!
I have the Futaba 3PK and seup the throttle / brake servo to trim in steps of 1/100th instead of 5/100ths (factory settings). I then just touch the brake trim to increse the drag brake. I can even adjust during a heat. Best done on the straight!!
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-19-2004, 06:39 AM   #5
Bandeira's Avatar
Default Re: Re: Drag Brake
With that you'll have your throttle neutal affected...
it would be better then to have the Throttle Acceleration function on on the dials(acessible by the LHand thumb) to you increase ThACC when you give more brake...
Old 07-19-2004, 07:56 AM   #6
ziggy12345's Avatar
Default Re: Re: Re: Drag Brake
Throttle neutral has to be set on the carb otherwise the throttle will be effected when you apply the brake. the throttle neutral has to be correct when there is a small gap between the servo link and the spring and the carb barrel is up against the throttle neutral adjusting screw
Cheers
Sponsored by:
Norfolk and Chance
Old 07-19-2004, 08:21 AM   #7
Bandeira's Avatar
Default Re: Re: Re: Re: Drag Brake
Cheers
I know I know... but if you, in order to get more drag brake, trim a little bit more on the brake side, you'll have a gap between the trigger neutral position and the moment when the servo will start opening the carb
Old 07-19-2004, 09:26 AM   #8
ziggy12345's Avatar
Ok got it now. yes thats correct but in reality its only 1-2mm and you dont notice it when applying the throttle
Sponsored by:
Norfolk and Chance
Old 07-31-2009, 05:13 PM   #9
auzzy_mate's Avatar
Default Stock Racing
Does anyone out there run much Drag/Auto Brake in Stock 17.5 racing.
I used to run 2/6 on my LRP but was thinking of going back to 0 for racing tomorrow, and then work my way up.
Ben
auzzy_mate is offline   Reply With Quote
3pk drag brake Nitro Herb Radio and Electronics 3 01-09-2008 07:00 PM
Drag Brake alan Nitro On-Road 9 10-27-2005 09:49 PM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
Drag brake Peter Busch Electric On-Road 7 06-26-2002 11:54 PM
