Old 07-17-2004, 06:25 PM   #1
serpentsixty9's Avatar
Send a message via AIM to serpentsixty9 Send a message via Yahoo to serpentsixty9
Default Need Help With Ntc3 clutch!
ok, i've been slowly rebuilding my ntc3, i got it used, no manual, but it was mostly assembled, and i've had plenty of nitro toureres, but all with centax clutches, never one with a standard 2 shoe. So, i go to the lhs, and i get some mip clutchshoes so they'll enhance the performance, i got an os .12 tr T, and i put the 2 shoe flywheel on, i tighten the clutch nut, i put the shoes on, then i pop the clutchbell and bearings on, and then i realized, i had no idea how to tighten it all down, i mean with centaxes i had thrust bearings, and shims and all this stuff, now i just have the end of the clutchbell, and about 3mm into the clutchbell, is the pilot shaft, what screw or shims do i need to complete the installation of the clutch? The engine has a sg shaft, thanks alot!
serpentsixty9 is offline   Reply With Quote
Old 07-17-2004, 06:33 PM   #2
mckrooz's Avatar
Send a message via AIM to mckrooz
All you need is like 1 small washer at the end and then tighten down with a cap screw. The washer is to make sure you're not tightening the bearing but putting the pressure on the washer itself.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 07-17-2004, 06:36 PM   #3
fordman500's Avatar
There is a shim kit you need.I dont know the exact part number but I do know they cost 1.00.If you dont use these on the front of the bearing it will be too tight and engage all the time.Ckeck Associateds website for the part number.
fordman500 is offline   Reply With Quote
Old 07-17-2004, 08:53 PM   #4
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
http://www.rc10.com/shusting/Catalog...hub_onroad.htm
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-17-2004, 09:09 PM   #5
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
you can download the WHOLE maual from www.teamassociated.com
Go to mauals and then NTC3
BigDogRacing is offline   Reply With Quote
Old 07-17-2004, 09:34 PM   #6
thanks alot u guys, it turns out i need part # 2321, i was missin those, cause when i tightened the screw, it put pressure on the whole clutchbell, and i couldn't even turn it. So hopefully with these washers, it'll make a difference.
GT2 to NTC3 clutch ????? Heynow2373 Nitro Off-Road 0 11-17-2007 03:05 PM
GPM NTC3 centex clutch mxs Nitro On-Road 30 12-13-2004 02:05 AM
NTC3 Clutch Question mrlacrosseman Nitro On-Road 7 08-26-2004 12:38 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
ntc3 clutch umbe Nitro On-Road 5 06-03-2002 12:24 AM
